A parallel hybrid method of GMRES on GRID system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Grid computing focuses on making use of a very large amount of resources from a large-scale computing environment. It intends to deliver high-performance computing over distributed platforms for computation and data-intensive applications. In this paper, we will present an effective parallel hybrid asynchronous method to solve large sparse linear systems by the use of a Grid Computing platform Grid5000. This hybrid method combines a parallel GMRES(m) (Generalized Minimum RESidual) algorithm with the Least Square method that needs some eigenvalues obtained from a parallel Arnoldi algorithm. All of these algorithms run on the different processors of the platform Grid5000. Grid5000, a 5000 CPUs nation-wide infrastructure for research in Grid computing, is designed to provide a scientific tool for computing. We discuss the performances of this hybrid method deployed on Grid5000, and compare these performances with those on the IBM SP series supercomputers.
Autre [cs.OH]
Fichier non déposé
hal-00689364 , version 1 (19-04-2012)
Ye Zhang, Guy Bergere, Serge Petiton. A parallel hybrid method of GMRES on GRID system. IPDPS'2007 : IEEE International Parallel and Distributed Processing Symposium, Mar 2007, Long Beach, California, United States. ⟨10.1109/IPDPS.2007.370546⟩. ⟨hal-00689364⟩
89 Consultations
0 Téléchargements
