Scaling Step-Wise Refinement, IEEE Transactions on Software Engineering, vol.30, 2004. ,
Using Modern Mathematics as an FOSD Modeling Language, pp.35-44, 2008. ,
Incremental Detection of Model Inconsistencies Based on Model Operations, LNCS, vol.5565, pp.32-46, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00669769
Detecting Model Inconsistency through Operation-Based Model Construction, pp.511-520, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01303728
Combining Independent Model Transformations, pp.2237-2243, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00516708
A Model-driven Approach to Develop Adaptive Firmwares, pp.168-177, 2011. ,
Confluence of Typed Attributed Graph Transformation Systems, ICGT '02: Proceedings of the First Int. Conference on Graph Transformation, pp.161-176, 2002. ,
FeatureOriented Domain Analysis (FODA)-Feasibility Study, The Software Engineering Institute, 1990. ,
A Case Study Implementing Features Using AspectJ, Proceedings of the 11th Int. Software Product Line Conference, pp.223-232, 2007. ,
Transactions on Aspect-Oriented Software Development VII-A Common Case Study for Aspect-Oriented Modeling, Lecture Notes in Computer Science, vol.6210, 2010. ,
, Transactions on AspectOriented Software Development VI, Special Issue on Aspects and Model-Driven Engineering, vol.5560, 2009.
An Overview of AspectJ, ECOOP '01: Procs of the 15th European Conference on Object-Oriented Programming, pp.327-353, 2001. ,
Crisis Management Systems: A Case Study for Aspect-Oriented Modeling, In: T. Aspect-Oriented Soft. Dev, issue.10, pp.1-22 ,
On the Modularity of Feature Interactions, Procs of the 7th int. conf. on Generative programming and Component Engineering, pp.23-34, 2008. ,
Type-Safe Delegation for Run-Time Component Adaptation, ECOOP 99 Object-Oriented Programming, vol.1628, pp.668-668, 1999. ,
Automatic Remodularization and Optimized Synthesis of Product-Families, Proceedings of the Third International Conference on Generative Programming and Component Engineering, pp.379-395, 2004. ,
Modeling Interactions in Feature Oriented Software Designs, pp.178-197, 2005. ,
Variational Attribute Grammars for Computer Aided Design (Release 3.0), 1994. ,
, Composing Adaptive Software. Computer, vol.37, pp.56-64, 2004.
Models@ Run.time to Support Dynamic Adaptation, Computer, vol.42, issue.10, pp.44-51, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-02054122
Workflow Design Using Fragment Composition-Crisis Management System Design through ADORE, T. AspectOriented Software Development, pp.200-233 ,
URL : https://hal.archives-ouvertes.fr/hal-00531026
Undoing Event-Driven Adaptation of Business Processes, 8th International Conference on Services Computing (SCC'11), pp.1-8, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00587660
Semantic-Based Interaction Detection in Aspect-Oriented Scenarios, pp.203-212, 2009. ,
Runtime Software Adaptation: Framework, Approaches, and Styles, Companion of the 30th int. conf. on Software engineering. pp. 899-910. ICSE Companion '08, 2008. ,
Feature-based Composition of Software Architectures, 4th European Conference on Software Architecture, vol.6285, pp.230-245, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00512716
, Constraint-Based Model Weaving. In: T. Aspect-Oriented Software Development VI, pp.153-190
MATA: A Unified Approach for Composing UML Aspect Models Based on Graph Transformation, T. Aspect-Oriented Software Development VI, pp.191-237 ,
