Eliminating Skolem Functions in Peano Arithmetic with Interactive Realizability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a new syntactical proof that first-order Peano Arithmetic with Skolem axioms is conservative over Peano Arithmetic alone for arithmetical formulas. This result -- which shows that the Excluded Middle principle can be used to eliminate Skolem functions -- has been previously proved by other techniques, among them the epsilon substitution method and forcing. In this paper, we employ Interactive Realizability, a computational semantics for Peano Arithmetic which extends Kreisel's modified realizability to the classical case.
ConservativeSKFull.pdf (287.95 Ko) Télécharger le fichier
hal-00690270 , version 1 (23-04-2012)
Federico Aschieri, Margherita Zorzi. Eliminating Skolem Functions in Peano Arithmetic with Interactive Realizability. Classical Logic and Computation 2012, Jul 2012, Warwick, United Kingdom. ⟨10.4204/EPTCS.97.1⟩. ⟨hal-00690270⟩
153 Consultations
120 Téléchargements
