Using Text Animated Transitions to Support Navigation in Document Histories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article examines the benefits of using text animated transitions for navigating in the revision history of textual documents. We propose an animation technique for smoothly transitioning between different text revisions, then present the Diffamation system. Diffamation supports rapid exploration of revision histories by combining text animated transitions with simple navigation and visualization tools. We finally describe a user study showing that smooth text animation allows users to track changes in the evolution of textual documents more effectively than flipping pages.
diffamation-CHI2010.pdf (1.12 Mo) Télécharger le fichier
Format : Figure, Image
hal-00690289 , version 1 (23-04-2012)
Fanny Chevalier, Pierre Dragicevic, Anastasia Bezerianos, Jean-Daniel Fekete. Using Text Animated Transitions to Support Navigation in Document Histories. International Conference on Human Factors in Computing Systems, ACM, Apr 2010, Atlanta, GA, United States. pp.683-692, ⟨10.1145/1753326.1753427⟩. ⟨hal-00690289⟩
321 Consultations
488 Téléchargements
