P2P B&B and GA for the flow-shop scheduling problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
Solving exactly Combinatorial Optimization Problems (COPs) using a Branch-and-Bound algorithm (B&B) requires a huge amount of computational resources. The efficiency of such algorithm can be improved by its hybridization with meta-heuristics such as Genetic Algorithms (GA) which proved their effectiveness, since they generate acceptable solutions in a reasonable time. Moreover, distributing at large scale the computation, using for instance Peer-to-Peer (P2P) Computing, provides an efficient way to reach high computing performance. In this chapter, we propose ParallelBB and ParallelGA, which are P2P-based parallelization of the B&B and GA algorithms for the computational Grid. The two algorithms have been implemented using the ProActive distributed object Grid middleware. The algorithms have been applied to a mono-criterion permutation flow-shop scheduling problem and promisingly experimented on the Grid5000 computational Grid.
Autre [cs.OH]
hal-00690360 , version 1 (23-04-2012)
Ahcène Bendjoudi, Samir Guerdah, Madjid Mansoura, Nouredine Melab, El-Ghazali Talbi. P2P B&B and GA for the flow-shop scheduling problem. Springer. Metaheuristics for Scheduling in Distributed Computing Environments, 146, Springer, pp.301-321, 2008, Studies in Computational Intelligence, ⟨10.1007/978-3-540-69277-5_11⟩. ⟨hal-00690360⟩
209 Consultations
0 Téléchargements
