New interface
Journal articles
Fractional-step schemes for the coupling of distributed and lumped models in hemodynamics
Cristobal Bertoglio 1 Alfonso Caiazzo 2 Miguel Angel Fernández 1, *
* Corresponding author
1 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : In three-dimensional (3D) blood flow simulations, lumped parameter models (0D) are often used to model the neglected parts of the downstream circulatory system. We analyze two 3D-0D coupling approaches in which a fractional-step projection scheme is used in the fluid. Our analysis shows that explicit approaches might yield numerical instabilities, particularly in the case of realistic geometries with multiple outlets. We introduce and analyze an implicitly 3D-0D coupled formulation with enhanced stability properties and which requires a negligible additional computational cost. Furthermore, we also address the extension of these methods to fluid-structure interaction problems. The theoretical stability results are confirmed by meaningful numerical experiments in patient specific geometries coming from medical imaging.
Document type :
Journal articles
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00690493
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Wednesday, February 6, 2013 - 10:03:26 PM
Last modification on : Friday, January 21, 2022 - 3:21:15 AM
Long-term archiving on: : Monday, June 17, 2013 - 7:55:42 PM
File
RR-7937.pdf
Identifiers
Citation
Cristobal Bertoglio, Alfonso Caiazzo, Miguel Angel Fernández. Fractional-step schemes for the coupling of distributed and lumped models in hemodynamics. SIAM Journal on Scientific Computing, 2013, 35 (3), pp.551-575. ⟨10.1137/120874412⟩. ⟨hal-00690493v2⟩
Share
Metrics
Record views
426
Files downloads
442
