Conference papers
FIRE: fault injection for reverse engineering
Abstract : In this paper, we propose a new technique that uses fault injection to reverse-engineer a private block cipher implemented with an unknown S-box. The private algorithm we wish to retrieve differs from a known algorithm in the choice of the S-Box, which we find using a novel, fault-injecting technique. The main idea is to consider the components of the S-Box as the solutions of a linear boolean system, whose equations stem from the faults injected, using existing fault models. We focus on two well-known block ciphers, DES and AES, and prove it to be feasible to retrieve the the S-Box for both cases. We present the fault models used, the equations extracted from the faults injected, and analyse the final results. Given the detailed analysis, the technique can be applied with ease to most ciphers employing an S-box.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-00690868
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Tuesday, April 24, 2012 - 3:43:45 PM
Last modification on : Monday, October 19, 2020 - 11:59:14 AM
File
978-3-642-21040-2_20_Chapter.p...
Identifiers
Citation
Manuel San Pedro, Mate Soos, Sylvain Guilley. FIRE: fault injection for reverse engineering. 5th Workshop on Information Security Theory and Practices (WISTP), Jun 2011, Heraklion, Crete, Greece. pp.280-293, ⟨10.1007/978-3-642-21040-2_20⟩. ⟨hal-00690868⟩
Share
Metrics
Record views
273
Files downloads
119
