SPARQL Query Containment under SHI Axioms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
SPARQL query containment under schema axioms is the problem of determining whether, for any RDF graph satisfying a given set of schema axioms, the answers to a query are contained in the answers of another query. This problem has major applications for verification and optimization of queries. In order to solve it, we rely on the mu-calculus. Firstly, we provide a mapping from RDF graphs into transition systems. Secondly, SPARQL queries and RDFS and SHI axioms are encoded into mu-calculus formulas. This allows us to reduce query containment and equivalence to satisfiability in the mu-calculus. Finally, we prove a double exponential upper bound for containment under SHI schema axioms.
RR-7943.pdf (893.49 Ko) Télécharger le fichier
hal-00691638 , version 1 (26-04-2012)
  • HAL Id : hal-00691638 , version 1
Melisachew Wudagae Chekol, Jérôme Euzenat, Pierre Genevès, Nabil Layaïda. SPARQL Query Containment under SHI Axioms. [Research Report] RR-7943, Inria - Sophia Antipolis. 2012. ⟨hal-00691638⟩
246 Consultations
134 Téléchargements
