Java Card 3 : Classic Functionality Gets a Connectivity Boost, access denied. 5. } References 1, 2009. ,
Tamper Resistance ? a Cautionary Note, Proceedings of the 2nd USENIX Workshop on Electronic Commerce, USENIX Association, pp.1-11, 1996. ,
Fault Attacks on RSA with CRT: Concrete Results and Practical Countermeasures, Cryptographic Hardware and Embedded Systems (CHES'02, pp.260-275, 2002. ,
DOI : 10.1007/3-540-36400-5_20
Fault Attacks on Java Card 3 Virtual Machine In: e-Smart'09, 2009. ,
Fault Attacks, an Intuitive Approach In: Fault Diagnosis and Tolerance in Cryptography (FDTC´06), 2006. ,
On the Importance of Checking Cryptographic Protocols for Faults, Advances in Cryptology -EUROCRYPT'97, pp.37-51, 1997. ,
DOI : 10.1007/3-540-69053-0_4
A Survey on Fault Attacks, Smart Card Research and Advanced Application Conference (CARDIS'04). LNCS, pp.159-176, 2004. ,
DOI : 10.1007/1-4020-8147-2_11
GlobalPlatform Card Specification 2.1.1, 2003. ,
GlobalPlatform Card Specification 2.2, 2006. ,
Using memory errors to attack a virtual machine, Proceedings 19th International Conference on Data Engineering (Cat. No.03CH37405), 2003. ,
DOI : 10.1109/SECPRI.2003.1199334
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.608
Use of Cryptographic Codes for Bytecode Verification in Smartcard Environment, 2003. ,
´ Evaluation de l'injection de code malicieux dans une Java Card, Symposium sur la Sécurité des Technologies de l'Information et de la Communication, 2009. ,
Introduction to Differential Power Analysis and Related Attacks, Cryptography Research Inc, 1998. ,
Differential Power Analysis, Advances in Cryptology -CRYPTO'99, pp.388-397, 1999. ,
DOI : 10.1007/3-540-48405-1_25
The Java Virtual Machine Specification, 1999. ,
Malicious Code on Java Card Smartcards: Attacks and Countermeasures, Smart Card Research and Advanced Application Conference (CARDIS'08). LNCS, pp.1-16, 2008. ,
DOI : 10.1007/978-3-540-30569-9_7
Reverse Engineering Java Card Applets Using Power Analysis, Proceedings of the 1st Workshop on Information Security Theory and Practice (WISTP'07, 2007. ,
DOI : 10.1109/TC.2002.1004593
Java Card Security, In: Information Security Bulletin, vol.8, pp.291-298, 2003. ,
