Expander graphs and sieving in combinatorial structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the Australian Mathematical Society Année : 2018
Graphes expanseurs et crible dans les structures combinatoires
Florent Jouve
  • Fonction : Auteur
  • PersonId : 914595
Jean-Sébastien Sereni
  • Fonction : Auteur
  • PersonId : 1026915
  • IdRef : 110354540
We prove a general large sieve statement in the context of random walks on subgraphs of a given graph. This can be seen as a generalization of previously known results where one performs a random walk on a group enjoying a strong spectral gap property. In such a context the point is to exhibit a strong uniform expansion property for a suitable family of Cayley graphs on quotients. In our combinatorial approach, this is replaced by a result of Alon--Roichman about expanding properties of random Cayley graphs. Applying the general setting we show e.g., that with high probability (in a strong explicit sense) random coloured subsets of integers contain monochromatic (non-empty) subsets summing to zero, or that a random coloring of the edges of a complete graph contains a monochromatic triangle.
egscs.pdf (401.62 Ko) Télécharger le fichier
hal-00693334 , version 1 (02-05-2012)
hal-00693334 , version 2 (16-05-2014)
hal-00693334 , version 3 (06-01-2017)
Florent Jouve, Jean-Sébastien Sereni. Expander graphs and sieving in combinatorial structures. Journal of the Australian Mathematical Society, 2018, 105 (1), pp.79--102. ⟨10.1017/S1446788717000234⟩. ⟨hal-00693334v3⟩
553 Consultations
281 Téléchargements
