HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Book sections
An efficient framework for running applications on clusters, grids, and clouds
Brian Amedro 1 Françoise Baude 1 Denis Caromel 1 Christian Delbé Imen Filali 1 Fabrice Huet 1 Elton Mathias 1 Oleg Smirnov 1
1 OASIS - Active objects, semantics, Internet and security
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : Since the appearance of distributed computing technology, there has been a significant effort in designing and building the infrastructure needed to tackle the challenges raised by complex scientific applications that require massive computational resources. This increases the awareness to harness the power and flexibility of Clouds that have recently emerged as an alternative to data centers or private clusters. We describe in this chapter an efficient high-level Grid and Cloud framework that allows a smooth transition from clusters and Grids to Clouds. The main lever is the ability to move application infrastructure-specific information away from the code and manage them in a deployment file. An application can thus easily run on a cluster, a grid, or a cloud, or any mix of them without modification.
Document type :
Book sections
Complete list of metadata
https://hal.inria.fr/hal-00694011
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Thursday, May 3, 2012 - 12:20:43 PM
Last modification on : Friday, February 4, 2022 - 3:08:59 AM
Identifiers
Collections
Citation
Brian Amedro, Françoise Baude, Denis Caromel, Christian Delbé, Imen Filali, et al.. An efficient framework for running applications on clusters, grids, and clouds. Nick Antonopoulos and Lee Gillam. Cloud Computing, Springer, pp.163-178, 2010, Computer Communications and Networks, 978-1849962407. ⟨10.1007/978-1-84996-241-4_10⟩. ⟨hal-00694011⟩
Share
Metrics
Record views
199
