Blind source separation based on time-frequency signal representations, IEEE Transactions on Signal Processing, vol.46, issue.11, pp.2888-2897, 1998. ,
DOI : 10.1109/78.726803
Underdetermined blind source separation using sparse representations, Signal Processing, vol.81, issue.11, pp.2353-2362, 2001. ,
DOI : 10.1016/S0165-1684(01)00120-7
Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004. ,
DOI : 10.1109/TSP.2004.828896
Survey of sparse and non-sparse methods in source separation, International Journal of Imaging Systems and Technology, vol.47, issue.33, pp.18-33, 2005. ,
DOI : 10.1002/ima.20035
Time???frequency ratio-based blind separation methods for attenuated and time-delayed sources, Mechanical Systems and Signal Processing, vol.19, issue.6, pp.1348-1379, 2005. ,
DOI : 10.1016/j.ymssp.2005.08.003
URL : https://hal.archives-ouvertes.fr/hal-00270877
A Robust Method to Count and Locate Audio Sources in a Multichannel Underdetermined Mixture, IEEE Transactions on Signal Processing, vol.58, issue.1, pp.121-133, 2010. ,
DOI : 10.1109/TSP.2009.2030854
URL : https://hal.archives-ouvertes.fr/inria-00489529
A wideband doubly-sparse approach for MITO sparse filter estimation, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2011. ,
DOI : 10.1109/ICASSP.2011.5947085
URL : https://hal.archives-ouvertes.fr/inria-00567210
Wideband algorithms versus narrowband algorithms for adaptive filtering in the DFT domain, Signals, Systems and Computers, Conference Record of the Thirty-Seventh Asilomar Conference on, pp.1278-1282, 2003. ,
Convolutive blind separation of non-stationary sources, IEEE Transactions on Speech and Audio Processing, vol.8, issue.3, pp.320-327, 2000. ,
DOI : 10.1109/89.841214
Blind source separation by sparse decomposition in a signal dictionary, in: Independent Component Analysis : Principles and Practice, pp.181-208, 2001. ,
Complex Nonconvex l p Norm Minimization for Underdetermined Source Separation, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.430-437, 2007. ,
DOI : 10.1007/978-3-540-74494-8_54
A Bayesian approach for blind separation of sparse sources, Audio, Speech, and Language Processing, IEEE Transactions on, vol.14, issue.6, pp.2174-2188, 2006. ,
Simple mixture model for sparse overcomplete ICA, IEE Proceedings on Vision, pp.35-43, 2004. ,
DOI : 10.1049/ip-vis:20040304
Underdetermined Instantaneous Audio Source Separation via Local Gaussian Modeling, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00482223
Wiener based source separation with HMM/GMM using a single sensor, Proc. ICA, pp.957-961, 2003. ,
Adaptation of Bayesian models for single-channel source separation and its application to voice/music separation in popular songs, Audio, Speech and Language Processing, IEEE Transactions on, vol.15, issue.5, pp.1564-1578, 2007. ,
Audio source separation with a single sensor, Audio, Speech, and Language Processing, IEEE Transactions on, vol.14, issue.1, pp.191-199, 2006. ,
Multichannel Nonnegative Matrix Factorization in Convolutive Mixtures for Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.3, pp.550-563, 2010. ,
DOI : 10.1109/TASL.2009.2031510
Maximum likelihood for blind separation and deconvolution of noisy signals using mixture models, Acoustics, Speech, and Signal Processing, 1997. ICASSP-97, IEEE International Conference on 5, pp.3617-3620, 1997. ,
Statistical decision theory and Bayesian analysis, 1985. ,
DOI : 10.1007/978-1-4757-4286-2
Dynamic compensation of HMM variances using the feature enhancement uncertainty computed from a parametric model of speech distortion, IEEE Transactions on Speech and Audio Processing, vol.13, issue.3, pp.412-421, 2005. ,
DOI : 10.1109/TSA.2005.845814
Supervised learning from incomplete data via the EM approach, Advances in Neural Information Processing Systems (NIPS), 1994. ,
Combining pitch-based inference and non-negative spectrogram factorization in separating vocals from polyphonic music, ISCA Tutorial and Research Workshop on Statistical And Perceptual Audition SAPA, 2008. ,
Independent Factor Analysis, Neural Computation, vol.4, issue.4, pp.803-851, 1999. ,
DOI : 10.1007/BF02293851
New EM algorithms for source separation and deconvolution, Proc. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.297-300, 2003. ,
DOI : 10.1109/icassp.2003.1199930
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.4233
A General Modular Framework for Audio Source Separation, 9th International Conference on Latent Variable Analysis and Signal Separation (LVA/ICA'10), pp.33-40, 2010. ,
DOI : 10.1007/978-3-642-15995-4_5
URL : https://hal.archives-ouvertes.fr/inria-00553504
Factorial hidden Markov models, Machine Learning, vol.29, issue.2/3, pp.245-273, 1997. ,
DOI : 10.1023/A:1007425814087
Blind Spectral-GMM Estimation for Underdetermined Instantaneous Audio Source Separation, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation, pp.751-758, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00482287
Pattern recognition and machine learning, 2006. ,
On circularity, IEEE Transactions on Signal Processing, vol.42, issue.12, pp.3473-3482, 2002. ,
DOI : 10.1109/78.340781
Adaptation de modèles statistiques pour la séparation de sources mono-capteur. ApplicationàApplication`Applicationà la séparation voix/musique dans les chansons, 2006. ,
The 2008 Signal Separation Evaluation Campaign: A Community-Based Approach to Large-Scale Evaluation, Proc. of International Conference on Independent Component Analysis and Signal Separation, 2009. ,
DOI : 10.1109/TASL.2007.899176
URL : https://hal.archives-ouvertes.fr/inria-00544168
Performance measurement in blind audio source separation, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.4, pp.1462-1469, 2006. ,
DOI : 10.1109/TSA.2005.858005
URL : https://hal.archives-ouvertes.fr/inria-00544230
Localization of amplitude-panned virtual sources I: stereophonic panning, Journal of the Audio Engineering Society, vol.49, issue.9, pp.739-752, 2001. ,
Roomsim, a MATLAB simulation of shoebox room acoustics for use in teaching and research, Computing and Information Systems, vol.9, issue.3, pp.48-51, 2005. ,
First Stereo Audio Source Separation Evaluation Campaign: Data, Algorithms and Results, Lecture Notes in Computer Science, vol.4666, issue.552, 2007. ,
DOI : 10.1007/978-3-540-74494-8_69
URL : https://hal.archives-ouvertes.fr/inria-00544199
Under-determined convolutive blind source separation using spatial covariance models, 2010 IEEE International Conference on Acoustics, Speech and Signal Processing, p.30, 2010. ,
DOI : 10.1109/ICASSP.2010.5496284
URL : https://hal.archives-ouvertes.fr/inria-00541863
Nonnegative matrix factorization and spatial covariance model for under-determined reverberant audio source separation, 10th International Conference on Information Science, Signal Processing and their Applications (ISSPA 2010), pp.1-4, 2010. ,
DOI : 10.1109/ISSPA.2010.5605570
URL : https://hal.archives-ouvertes.fr/inria-00541436
Bayesian parameter estimation via variational methods, Statistics and Computing, vol.10, issue.1, pp.25-37, 2000. ,
DOI : 10.1023/A:1008932416310
Spatial covariance models for under-determined reverberant audio source separation, 2009 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.129-132, 2009. ,
DOI : 10.1109/ASPAA.2009.5346503
URL : https://hal.archives-ouvertes.fr/hal-00481529
