HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Componentising a Scientific Application for the Grid
Nikos Parlavantzas 1, 2 Matthieu Morel 2 Françoise Baude 2 Fabrice Huet 2 Denis Caromel 2 Vladimir Getov 1
2 OASIS - Active objects, semantics, Internet and security
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : Building and evolving Grid applications is complex. Component-based development has emerged as an effective approach to building flexible systems, but there is little experience in applying this approach to Grid programming. This paper presents our experience with reengineering a high performance numerical solver to become a component-based Grid application. The adopted component model is an extension of the generic Fractal model that specifically targets grid environments. The paper provides qualitative and quantitative evidence that componentisation has improved the modifiability and reusability of the application while not significantly affecting performance.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/hal-00694511
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Friday, May 4, 2012 - 2:57:47 PM
Last modification on : Friday, February 4, 2022 - 3:20:09 AM
Identifiers
  • HAL Id : hal-00694511, version 1
Collections
Citation
Nikos Parlavantzas, Matthieu Morel, Françoise Baude, Fabrice Huet, Denis Caromel, et al.. Componentising a Scientific Application for the Grid. [Technical Report] 2006. ⟨hal-00694511⟩
Share
Metrics
Record views
123
