Comparison of Search Engines Non-Neutral and Neutral Behaviors
Pierre Coucheney 1 Patrick Maillé 2, 3 Bruno Tuffin 1
1 DIONYSOS - Dependability Interoperability and perfOrmance aNalYsiS Of networkS
Inria Rennes – Bretagne Atlantique , IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
2 OCIF - Objets communicants pour l'Internet du futur
Télécom Bretagne, IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
Abstract : Network neutrality has recently attracted a lot of attention but search neutrality is also becoming a vivid subject of discussion because a non-neutral search may prevent some relevant content from being accessed by users. We propose in this paper to model two situations of a non-neutral search engine behavior, which can rank the link propositions according to the pro t a search can generate for it instead of just relevance: the case when the search engine owns some content, and the case when it imposes a tax on organic links, a bit similarly to what it does for commercial links. We analyze the particular (and deterministic) situation of a single keyword, and describe the problem for the whole potential set of keywords.
Type de document :
Pré-publication, Document de travail
2012
Liste complète des métadonnées
https://hal.inria.fr/hal-00694524
Contributeur : Pierre Coucheney <>
Soumis le : vendredi 4 mai 2012 - 15:29:28
Dernière modification le : mercredi 6 mars 2019 - 15:09:43
Document(s) archivé(s) le : vendredi 30 novembre 2012 - 11:05:45
Fichier
W-PIN-Search-Neutrality.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00694524, version 1
Citation
Pierre Coucheney, Patrick Maillé, Bruno Tuffin. Comparison of Search Engines Non-Neutral and Neutral Behaviors. 2012. 〈hal-00694524〉
Métriques
Consultations de la notice
740
Téléchargements de fichiers
464
