New interface
Conference papers
Image assimilation with the weighted ensemble Kalman filter
Cuzol Anne 1 Etienne Mémin 1
1 FLUMINANCE - Fluid Flow Analysis, Description and Control from Image Sequences
CEMAGREF - Centre national du machinisme agricole, du génie rural, des eaux et forêts, Inria Rennes – Bretagne Atlantique
Abstract : We present a sequential data assimilation method based on the combination of two assimilation techniques: the ensemble Kalman filter (EnKF) and the particle filter. Both techniques are based on Monte Carlo sampling allowing approximate solving of non linear stochastic filtering problems. However, while the EnKF is still based on a Gaussian assumption, the particle filter does not rely on such an assumption but is known to be less efficient when the number of available samples is small. In practice, both techniques are combined in the sense that the sampling step of the particle filter is based on the EnKF technique, followed by a weighting of samples using observations. The association of these two approaches is a step toward an efficient application of ensemble techniques to high-dimensional and non linear / non Gaussian problems, such as those encountered in meteorology or oceanography. We show the performances of this new approach on high-dimensional problems where the goal is to filter turbulent velocity fields from image observations. The assimilation technique associates a non linear stochastic dynamical model to linear observations extracted from the image sequences, or directly to the image data through a non linear observation operator. The method has been validated on a synthetic sequence, and applied to real oceanographic satellite image sequences of SST (sea surface temperature). This work corresponds to an extension of the preliminary study published in Tellus (N. Papadakis, E. Memin, A. Cuzol, N. Gengembre. Data assimilation with the Weighted Ensemble Kalman Filter. Tellus A, vol.62(5), p. 673-697, 2010). In a second part, we present a way to improve the assimilation when the time step between observations (images) is very long. We make use of a conditional simulation technique in order to reduce dynamical discontinuities produced in that case by the sequential techniques.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00694782
Contributor : Etienne Memin Connect in order to contact the contributor
Submitted on : Sunday, May 6, 2012 - 5:21:37 PM
Last modification on : Friday, December 2, 2022 - 10:04:04 AM
Identifiers
  • HAL Id : hal-00694782, version 1
Citation
Cuzol Anne, Etienne Mémin. Image assimilation with the weighted ensemble Kalman filter. International Workshop on Adjoint Model Applications in Dynamic Meteorology, Oct 2011, Cefalu, Sicilia,, Italy. ⟨hal-00694782⟩
Share
Metrics
Record views
137
