KBAC: Knowledge-Based Admission Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Many methods have been proposed in the literature to perform admission control in order to provide a sufficient level of Quality of Service (QoS) to accepted flows. In this paper, we introduce a novel data-driven method based on a time-varying model that we refer to as Knowledge-Based Admission Control solution (KBAC). Our KBAC solution consists of three main stages: (i) collect measurements on the on-going traffic over the communication link; (ii) maintain an up-to-date broad view of the link behavior, and feed it to a Knowledge Plane; (iii) model the observed link behavior by a mono-server queue whose parameters are set automatically and which predicts the expected QoS if a flow requesting admission were to be accepted. Our KBAC solution provides a probabilistic guarantee whose admission threshold is either expressed, as a bounded delay or as a bounded loss rate. We run extensive simulations to assess the behavior of our KBAC solution in the case of a delay threshold. The results show that our KBAC solution leads to a good trade-off between flow performance and resource utilization. This ability stems from the quick and automatic adjustment of its admission policy according to the actual variations on the traffic conditions.
RR-7955.pdf (810.1 Ko) Télécharger le fichier
hal-00695335 , version 1 (07-05-2012)
  • HAL Id : hal-00695335 , version 1
Doreid Ammar, Thomas Begin, Isabelle Guérin-Lassous, Ludovic Noirie. KBAC: Knowledge-Based Admission Control. [Research Report] RR-7955, INRIA. 2012. ⟨hal-00695335⟩
213 Consultations
286 Téléchargements
