A. M. Behr, J. Cohen-or, D. Fleishman, S. Levin, D. Silva et al., Point set surfaces, IEEE Visualization, 2001.
M. Alexa, J. Behr, D. Cohen-or, S. Fleishman, D. Levin et al., Computing and rendering point set surfaces, IEEE Transactions on Visualization and Computer Graphics, vol.9, issue.1, pp.3-15, 2003.
DOI : 10.1109/TVCG.2003.1175093
N. Amenta and Y. J. Kil, The Domain of a Point Set Surface, Eurographics Symposium on Point-Based Graphics, 2004.
N. Amenta and Y. J. Kil, Defining Point-Set Surfaces, Proceedings SIGGRAPH 04, 2004.
S. Azernikov, A. Miropolsky, and A. Fischer, Surface reconstruction of freeform objects based on multiresolution volumetric method, ACM symposium on Solid modeling and applications (SM '03), 2003.
J. Daniels, L. Ha, T. Ochotta, and T. Silva, Robust Smooth Feature Extraction from Point Clouds, IEEE International Conference on Shape Modeling and Applications 2007 (SMI '07), 2005.
DOI : 10.1109/SMI.2007.32
J. Daniels, L. Ha, T. Ochotta, and T. Silva, Splinebased feature curves from point-sampled geometry, The Visual Computer, vol.24, issue.6, 2008.
T. K. Dey and J. Sun, An Adaptive MLS Surface for Reconstruction with Guarantees, Symposium on Geometry Processing, 2005.
S. Fleishman, D. Cohen-or, and C. Silva, Robust moving leastsquares fitting with sharp features, ACM Trans. Graph, pp.37-49, 2005.
M. Gross and H. Pfister, Point-Based Graphics. The Morgan Kaufmann Series in Computer Graphics, 2007.
G. Guennebaud and M. Gross, Algebraic point set surfaces, Proceedings SIGGRAPH 07, 2007.
DOI : 10.1145/1275808.1276406
URL : https://hal.archives-ouvertes.fr/inria-00354998
G. Guennebaud, M. Germann, and M. Gross, Dynamic Sampling and Rendering of Algebraic Point Set Surfaces Computer Graphics Forum, pp.653-662, 2008.
K. Hildebrand, K. Polthier, and K. Wardetzky, Smooth feature lines on surface meshes, Proceedings of Symposium on Geometric Processing, 2005.
A. Hubeli and M. Gross, Multiresolution feature extraction for unstructured meshes, Proceedings Visualization, 2001. VIS '01., pp.287-294, 2001.
DOI : 10.1109/VISUAL.2001.964523
R. Kolluri, Provably good moving least squares, ACM SIAM Symposium on Discrete Algorithms, 2005.
DOI : 10.1145/1361192.1361195
D. Levin, The approximation power of moving least-squares, Mathematics of Computation, vol.67, issue.224, pp.1517-1531, 1998.
DOI : 10.1090/S0025-5718-98-00974-0
D. Levin, Mesh-independent surface interpolation Geometric Modeling for Scientific Visualization, pp.37-49, 2003.
DOI : 10.1007/978-3-662-07443-5_3
Y. Lipman, D. Cohen-or, and D. Levin, Data-dependent MLS for faithful surface approximation, Symposium on Geometry Processing, pp.59-67, 2008.
Q. Mérigot, M. Ovsjanikov, and L. J. Guibas, Robust Voronoi-based curvature and feature estimation, 2009 SIAM/ACM Joint Conference on Geometric and Physical Modeling on, SPM '09, pp.1-12, 2009.
DOI : 10.1145/1629255.1629257
C. Oztireli, G. Guennebaud, and M. Gross, Feature Preserving Point Set Surfaces based on Non-Linear Kernel Regression, Computer Graphics Forum, vol.16, issue.2, p.2, 2009.
DOI : 10.1111/j.1467-8659.2009.01388.x
URL : https://hal.archives-ouvertes.fr/inria-00354969
S. Gumhold, X. Wang, and R. Mcleod, Feature extraction from point clouds, Proceedings of 10th International Meshing Roundtable V, 2001.
Y. Ohtake, A. Belyaev, M. Alexa, G. Turk, and H. Seidel, Multi-level partition of unity implicits, Proceedings SIGGRAPH 2003, 2003.
M. Pauly, R. Keiser, and M. Gross, Multi-scale Feature Extraction on Point-Sampled Surfaces, Computer Graphics Forum, vol.30, issue.2, 2003.
DOI : 10.1111/1467-8659.00675
P. Reuter, P. Joyot, J. Trunzler, T. Boubekeur, and C. Schlick, Surface reconstruction with enriched reproducing kernel particle approximation, Proceedings Eurographics/IEEE VGTC Symposium Point-Based Graphics, 2005., 2005.
DOI : 10.1109/PBG.2005.194068
URL : https://hal.archives-ouvertes.fr/inria-00260890
C. E. Scheidegger, S. Fleishman, and C. Silva, Triangulating point set surfaces with bounded error, Symposium on Geometry Processing, pp.63-72, 2005.
J. Schreiner, C. Scheidegger, S. Fleishman, and C. Silva, Direct (Re)Meshing for Efficient Surface Processing, Computer Graphics Forum, vol.25, issue.4
DOI : 10.1145/1015706.1015774
C. Shen, J. F. O-'brien, and J. Shewchuk, Interpolating and approximating implicit surfaces from polygon soup, ACM Transactions on Graphics, vol.23, issue.3, pp.896-904, 2004.
DOI : 10.1145/1015706.1015816
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.70.4924
K. Watanabe and A. Belyaev, Detection of Salient Curvature Features on Polygonal Surfaces, Computer Graphics Forum, vol.20, issue.3, pp.385-392, 2001.
DOI : 10.1111/1467-8659.00531
C. Weber, S. Hahmann, and H. Hagen, Sharp feature detection in point clouds, 2010 Shape Modeling International Conference, 2010.
DOI : 10.1109/SMI.2010.32
URL : https://hal.archives-ouvertes.fr/hal-00568051
T. Weinkauf and D. Günther, Separatrix Persistence: Extraction of Salient Edges on Surfaces Using Topological Methods, Proc. SGP '09), pp.1519-1528, 2009.
DOI : 10.1111/j.1467-8659.2009.01528.x
