Wavelet-based fluid motion estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on a wavelet expansion of the velocity field, we present a novel optical flow algorithm dedicated to the estimation of continuous motion fields such as fluid flows. This scale-space representation, associated to a simple gradient-based optimization algorithm, naturally sets up a well-defined multi-resolution analysis framework for the optical flow estimation problem, thus avoiding the common drawbacks of standard multi-resolution schemes. Moreover, wavelet properties enable the design of simple yet efficient high-order regularizers or polynomial approximations associated to a low computational complexity. Accuracy of proposed methods is assessed on challenging sequences of turbulent fluids flows.
paper-55_final.pdf (771.23 Ko) Télécharger le fichier
hal-00695549 , version 1 (09-05-2012)
  • HAL Id : hal-00695549 , version 1
Pierre Dérian, Patrick Héas, Cédric Herzet, Etienne Mémin. Wavelet-based fluid motion estimation. SSVM 2011 - Third International Conference on Scale Space and Variational Methods in Computer Vision, 2011, Ein-Gedi, Israel. ⟨hal-00695549⟩
310 Consultations
352 Téléchargements
