Wavelets to reconstruct turbulence multifractals from experimental image sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the context of turbulent fluid motion measurement from image sequences, we propose in this paper to reverse the traditional point of view of wavelets perceived as an analyzing tool: wavelets and their properties are now considered as prior regularization models for the motion estimation problem, in order to exhibit some well-known turbulence regularities and multifractal behaviors on the reconstructed motion field.
paper_130875.pdf (287.31 Ko) Télécharger le fichier
hal-00695552 , version 1 (09-05-2012)
  • HAL Id : hal-00695552 , version 1
Pierre Dérian, Patrick Héas, Etienne Mémin. Wavelets to reconstruct turbulence multifractals from experimental image sequences. TSFP7 - 7th International Symposium on Turbulence and Shear Flow Phenomena, Jul 2011, Ottawa, Canada. ⟨hal-00695552⟩
252 Consultations
198 Téléchargements
