Low Mach Number Limit of the Full Navier-Stokes Equations, Archive for Rational Mechanics and Analysis, vol.180, issue.1, pp.1-73, 2006. ,
DOI : 10.1007/s00205-005-0393-2
URL : https://hal.archives-ouvertes.fr/hal-00153152
On the difference approximations of overdetermined hyperbolic equations of classical mathematical physics, Computational Mathematics and Mathematical Physics, vol.47, issue.3, pp.427-441, 2007. ,
DOI : 10.1134/S0965542507030086
The design and application of upwind schemes on unstructured meshes, 27th Aerospace Sciences Meeting, 1989. ,
DOI : 10.2514/6.1989-366
On Low Mach Number Preconditioning of Finite Volume Schemes, PAMM, vol.72, issue.1, pp.759-760, 2005. ,
DOI : 10.1002/pamm.200510354
An all-speed relaxation scheme for interface flows with surface tension, Journal of Computational Physics, vol.228, issue.16, pp.5722-5739, 2009. ,
DOI : 10.1016/j.jcp.2009.04.046
Simplified Second-Order Godunov-Type Methods, SIAM Journal on Scientific and Statistical Computing, vol.9, issue.3, pp.445-473, 1988. ,
DOI : 10.1137/0909030
The Motion of Slightly Compressible Fluids Viewed as a Motion With Strong Constraining Force, The Annals of Mathematics, vol.105, issue.1, pp.141-200, 1977. ,
DOI : 10.2307/1971029
Solid???fluid diffuse interface model in cases of extreme deformations, Journal of Computational Physics, vol.228, issue.16, pp.6037-6077, 2009. ,
DOI : 10.1016/j.jcp.2009.05.015
A Non-oscillatory Eulerian Approach to Interfaces in Multimaterial Flows (the Ghost Fluid Method), Journal of Computational Physics, vol.152, issue.2, pp.457-492, 1999. ,
DOI : 10.1006/jcph.1999.6236
Three-Dimensional Front Tracking, SIAM Journal on Scientific Computing, vol.19, issue.3, pp.703-727, 1998. ,
DOI : 10.1137/S1064827595293600
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.57.569
On the behaviour of upwind schemes in the low mach number limit. Computers and Fluids, pp.63-86, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00871725
On the behaviour of upwind schemes in the low Mach number limit, Computers & Fluids, vol.28, issue.1, pp.63-86, 1999. ,
DOI : 10.1016/S0045-7930(98)00017-6
Fluid dynamics, pp.1678-1712, 1971. ,
A numerical fluid dynamics calculation method for all flow speeds, Journal of Computational Physics, vol.8, issue.2, pp.197-213, 1971. ,
DOI : 10.1016/0021-9991(71)90002-7
On Upstream Differencing and Godunov-Type Schemes for Hyperbolic Conservation Laws, SIAM Review, vol.25, issue.1, pp.35-61, 1983. ,
DOI : 10.1137/1025002
Volume of fluid (VOF) method for the dynamics of free boundaries, Journal of Computational Physics, vol.39, issue.1, pp.201-255, 1981. ,
DOI : 10.1016/0021-9991(81)90145-5
Computations of boiling flows, International Journal of Multiphase Flow, vol.24, issue.3, pp.387-410, 1998. ,
DOI : 10.1016/S0301-9322(97)00050-5
Two-phase modeling of deflagration-to-detonation transition in granular materials: Reduced equations, Physics of Fluids, vol.13, issue.10, pp.3002-3024, 2001. ,
DOI : 10.1063/1.1398042
Singular limits of quasilinear hyperbolic systems with large parameters and the incompressible limit of compressible fluids, Communications on Pure and Applied Mathematics, vol.71, issue.4, pp.481-524, 1981. ,
DOI : 10.1002/cpa.3160340405
An anti-diffusive numerical scheme for the simulation of interfaces between compressible fluids by means of a five-equation model, Journal of Computational Physics, vol.229, issue.8, pp.2773-2809, 2010. ,
DOI : 10.1016/j.jcp.2009.12.003
Modelling Merging and Fragmentation in Multiphase Flows with SURFER, Journal of Computational Physics, vol.113, issue.1, pp.134-147, 1994. ,
DOI : 10.1006/jcph.1994.1123
Revisiting the Least-Squares Procedure for Gradient Reconstruction on Unstructured Meshes, 16th AIAA Computational Fluid Dynamics Conference, p.3986, 2003. ,
DOI : 10.2514/6.2003-3986
Coupling level set/VOF/ghost fluid methods: Validation and application to 3D simulation of the primary break-up of a liquid jet, International Journal of Multiphase Flow, vol.33, issue.5, pp.510-524, 2007. ,
DOI : 10.1016/j.ijmultiphaseflow.2006.11.001
URL : https://hal.archives-ouvertes.fr/hal-00649785
The Riemann problem for fluid flow of real materials, Reviews of Modern Physics, vol.61, issue.1, pp.75-130, 1989. ,
DOI : 10.1103/RevModPhys.61.75
The Incompressible Limit of the Non-Isentropic Euler Equations, Archive for Rational Mechanics and Analysis, vol.158, issue.1, pp.61-90, 2001. ,
DOI : 10.1007/PL00004241
Élaboration des lois d'état d'un liquide et de sa vapeur pour les modèles d'écoulements diphasiques, French)), pp.265-276, 2004. ,
Evaluation of the turbulence model influence on the numerical simulations of unsteady cavitation, J. Fluid Engineering, vol.125, issue.1, pp.38-45, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00211202
A compressible flow model with capillary effects, Journal of Computational Physics, vol.209, issue.1, pp.139-178, 2005. ,
DOI : 10.1016/j.jcp.2005.03.018
A relaxation-projection method for compressible flows. Part II: Artificial heat exchanges for multiphase shocks, Journal of Computational Physics, vol.225, issue.2, pp.2214-2248, 2007. ,
DOI : 10.1016/j.jcp.2007.03.014
Diffuse interface model for high speed cavitating underwater systems, International Journal of Multiphase Flow, vol.35, issue.8, pp.747-759, 2009. ,
DOI : 10.1016/j.ijmultiphaseflow.2009.03.011
Modelling detonation waves in condensed energetic materials: multiphase CJ conditions and multidimensional computations, Shock Waves, vol.22, issue.4, pp.377-401, 2009. ,
DOI : 10.1007/s00193-009-0217-7
Numerical methods for large eigenvalue problems, 1992. ,
DOI : 10.1137/1.9781611970739
A Multiphase Godunov Method for Compressible Multifluid and Multiphase Flows, Journal of Computational Physics, vol.150, issue.2, pp.425-467, 1999. ,
DOI : 10.1006/jcph.1999.6187
A relaxation-projection method for compressible flows. Part I: The numerical equation of state for the Euler equations, Journal of Computational Physics, vol.223, issue.2, pp.822-845, 2007. ,
DOI : 10.1016/j.jcp.2006.10.004
Shock jump relations for multiphase mixtures with stiff mechanical relaxation, Shock Waves, vol.56, issue.3, pp.209-232, 2007. ,
DOI : 10.1007/s00193-006-0065-7
Modelling dynamic and irreversible powder compaction, Journal of Fluid Mechanics, vol.30, pp.348-396, 2010. ,
DOI : 10.1016/j.jcp.2008.11.002
URL : https://hal.archives-ouvertes.fr/hal-01443539
Simple and efficient relaxation methods for interfaces separating compressible fluids, cavitating flows and shocks in multiphase mixtures, Journal of Computational Physics, vol.228, issue.5, pp.1678-1712, 2009. ,
Modelling phase transition in metastable liquids: application to cavitating and flashing flows, Journal of Fluid Mechanics, vol.15, pp.313-350, 2008. ,
DOI : 10.1017/S0022112087003227
URL : https://hal.archives-ouvertes.fr/inria-00333908
The compressible Euler equations in a bounded domain: Existence of solutions and the incompressible limit, Communications in Mathematical Physics, vol.8, issue.1, pp.49-75, 1986. ,
DOI : 10.1007/BF01210792
An interface capturing method for the simulation of multi-phase compressible flows, Journal of Computational Physics, vol.229, issue.19, pp.7411-7439, 2010. ,
DOI : 10.1016/j.jcp.2010.06.025
Restoration of the contact surface in the HLL-Riemann solver, Shock Waves, vol.54, issue.1, pp.25-34, 1994. ,
DOI : 10.1007/BF01414629
Towards the ultimate conservative difference scheme, V.A second order sequel to Godunov's method, J. Comput. Phys, vol.32, pp.445-473, 1979. ,
