Design Preserving Garment Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2012
We present a fully automatic method for design-preserving transfer of garments between characters with different body shapes. For real life garments, such transfer is performed through a knowledge intensive and time consuming process, known as pattern grading. Our first contribution is to reformulate the criteria used in professional pattern-grading as a set of geometric requirement, respectively expressing shape or design preservation, proportionality, and fit. We then propose a fully automatic garment transfer algorithm which satisfies all of these criteria while ensuring the physical plausibility of result.
GarmentTransfer.pdf (39.6 Mo) Télécharger le fichier
GarmentTransferH264_640x360.mov (61.09 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00695903 , version 1 (16-07-2012)
hal-00695903 , version 2 (25-09-2012)
Rémi Brouet, Alla Sheffer, Laurence Boissieux, Marie-Paule Cani. Design Preserving Garment Transfer. ACM Transactions on Graphics, 2012, SIGGRAPH 2012, 31 (4), pp.Article No. 36. ⟨10.1145/2185520.2185532⟩. ⟨hal-00695903v2⟩
2902 Consultations
3756 Téléchargements
