Conference papers
Homologous and Nonhomologous Rearrangements: Interactions and Effects on Evolvability.
David P. Parsons 1, 2 Carole Knibbe 1, 2 Guillaume Beslon 2, 1
2 BEAGLE - Artificial Evolution and Computational Biology
LIRIS - Laboratoire d'InfoRmatique en Image et Systèmes d'information, Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
Abstract : By using Aevol, a simulation framework designed to study the evolution of genome structure, we investigate the effect of homologous rearrangements on the course of evolution. We designed an efficient model of rearrangements based on an intermittent search algorithm. Then, using experimental in silico evolution, we explore the effect of rearrangement rates on the genome structure. We show that the effect of homologous rearrangements is quite complex. At first glance they appear to be dangerous enough to trigger an indirect selective pressure leading to short genomes when the rearrangement rate is high. However, by analyzing the successful lineage in the best runs, we found that there is a positive correlation between the number of homologous rearrangements and the fitness improvement in these lineages. Thus the impact of homologous rearrangements on evolution is rather complex: dangerous on the one hand but necessary on the other hand, to ensure a sufficient level of evolvability to the organisms. Moreover, our results show that the spontaneous rate of small mutations influences the relative proportions of homologous versus nonhomologous rearrangements.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00696902
Contributor : David Parsons Connect in order to contact the contributor
Submitted on : Monday, May 14, 2012 - 10:05:10 AM
Last modification on : Friday, September 30, 2022 - 11:34:15 AM
Identifiers
  • HAL Id : hal-00696902, version 1
Citation
David P. Parsons, Carole Knibbe, Guillaume Beslon. Homologous and Nonhomologous Rearrangements: Interactions and Effects on Evolvability.. Proceedings of the Eleventh European Conference on the Synthesis and Simulation of Living Systems (ECAL 11), Aug 2011, Paris, France. pp.622--629. ⟨hal-00696902⟩
Share
Metrics
Record views
161
