Threading Building Blocks, 2009. ,
Compute Unified Device Architecture Programming Guide, 2007. ,
Introduction to the Cell multiprocessor, IBM Journal of Research and Development, vol.49, issue.4.5, pp.4-5, 2005. ,
DOI : 10.1147/rd.494.0589
Composing Parallel Software Efficiently with Lithe, Proceedings of the 2010 ACM SIGPLAN Conference on Programming Language Design and Implementation, ser. PLDI '10, pp.376-387, 2010. ,
PetaBricks: A Language and Compiler for Algorithmic Choice, Proceedings of the 2009 ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.38-49, 2009. ,
Elastic Computing: A Framework for Transparent , Portable, and Adaptive Multi-core Heterogeneous Computing, Proceedings of the ACM SIGPLAN/SIGBED 2010 Conference on Languages, Compilers, and Tools for Embedded Systems (LCTES, pp.115-124, 2010. ,
Parallel Programming of General-Purpose Programs using Task-based Programming Models, Proceedings of the 3rd USENIX Conference on Hot Topics in Parallelism, ser. HotPar'11, pp.13-13, 2011. ,
PEPPHER: Efficient and Productive Usage of Hybrid Computing Systems, IEEE Micro, vol.31, issue.5, pp.28-41, 2011. ,
DOI : 10.1109/MM.2011.67
URL : https://hal.archives-ouvertes.fr/hal-00648480
Using explicit platform descriptions to support programming of heterogeneous many-core systems, Parallel Computing, vol.38, issue.1-2, pp.52-65, 2012. ,
DOI : 10.1016/j.parco.2011.10.008
StarPU: A Unified Platform for Task Scheduling on Heterogeneous Multicore Architectures Concurrency and Computation: Practice and Experience, pp.187-198, 2011. ,
ROSE: Compiler Support for Object-Oriented Frameworks, Parallel Processing Letters, vol.49, 2005. ,
Performance-effective and low-complexity task scheduling for heterogeneous computing, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.3, 2002. ,
DOI : 10.1109/71.993206
A Block-Sorting Lossless Data Compression Algorithm, Digital Systems Research Center, 1994. ,
Intel Threading Building Blocks -Pipeline Documentation ,
BZIP2 Library Utility Function Documentation, 2011. ,
Parallel Data Compression with bzip2, Proceedings of the 16th IASTED International Conference on Parallel and Distributed Computing and Systems, pp.559-564, 2004. ,
Learning openCV: Computer Vision with the openCV Library, 2008. ,
Mapping Pipeline Skeletons onto Heterogeneous Platforms, ICCS '07: Proceedings of the 7th international conference on Computational Science, 2007. ,
DOI : 10.1016/j.jpdc.2007.11.004
URL : https://hal.archives-ouvertes.fr/hal-00118921
Bringing skeletons out of the closet: a pragmatic manifesto for skeletal parallel programming, Parallel Computing, vol.30, issue.3, 2004. ,
DOI : 10.1016/j.parco.2003.12.002
A stream-computing extension to OpenMP, Proceedings of the 6th International Conference on High Performance and Embedded Architectures and Compilers, HiPEAC '11, 2011. ,
DOI : 10.1145/1944862.1944867
URL : https://hal.archives-ouvertes.fr/hal-00659411
StreamIt: A Language for Streaming Applications, CC '02: Proceedings of the 11th International Conference on Compiler Construction, 2002. ,
DOI : 10.1007/3-540-45937-5_14
Cache Aware Optimization of Stream Programs, ACM SIGPLAN Notices, vol.40, issue.7, 2005. ,
Engineering parallel applications with tunable architectures, Proceedings of the 32nd ACM/IEEE International Conference on Software Engineering, ICSE '10, 2010. ,
DOI : 10.1145/1806799.1806859
A Language-Based Tuning Mechanism for Task and Pipeline Parallelism, Euro-Par'10: Proceedings of the 16th international Euro-Par conference on Parallel processing: Part II, 2010. ,
DOI : 10.1007/978-3-642-15291-7_30
Feedback-directed pipeline parallelism, Proceedings of the 19th international conference on Parallel architectures and compilation techniques, PACT '10, 2010. ,
DOI : 10.1145/1854273.1854296
A Proposal to Extend the OpenMP Tasking Model for Heterogeneous Architectures, Evolving OpenMP in an Age of Extreme Parallelism, 5th International Workshop on OpenMP (IWOMP), pp.154-167, 2009. ,
DOI : 10.1007/978-3-540-79561-2_10
Implementing the PGI Accelerator model, Proceedings of the 3rd Workshop on General-Purpose Computation on Graphics Processing Units, GPGPU '10, 2010. ,
DOI : 10.1145/1735688.1735697
Heterogeneous Multicore Parallel Programming for Graphics Processing Units, Scientific Programming, pp.325-335, 2009. ,
DOI : 10.1155/2009/784893
