New interface
Conference papers
Performance evaluation of meta-data transfer and storage in clusters
Abstract : An expressive number of scientific application executed on cluster architectures need some form of permanent storage with high capacity. As a consequence, the performance of the storage system becomes crucial to such applications. Besides granting data I/O performance, it's important to provide efficient and scalable access to file's meta-data, allowing the system to scale and, yet, offer a good level of consistency in the shared file system. Also the file transfer between nodes of the cluster architectures is an important factor that affects the I/O performance. And this is important to know the behavior and influence in the shared file system. In this paper we present a low-overhead meta-data synchronization algorithm used in dNFSp, a distributed file system based on NFS that proposes changes exclusively on the server side, keeping compatibility with traditional NFS clients. With this synchronization schema, dNFSp can offer the same level of coherence of traditional NFS servers. We also evaluate the communication characteristics of the environment where the tests were executed in order to analyze possibilities of scalability of the system.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00697472
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Tuesday, May 15, 2012 - 2:23:04 PM
Last modification on : Thursday, August 4, 2022 - 4:53:40 PM
Identifiers
  • HAL Id : hal-00697472, version 1
Collections
Citation
Everton Hermann, Rodrigo V. Kassick, Rafael B. Ávila, Carlos Barrios-Hernandez, Michel Riveill, et al.. Performance evaluation of meta-data transfer and storage in clusters. CLCAR 2007 : Latinoamericana Conference of High Performance Computing, Aug 2007, Santa Marta, Colombia. ⟨hal-00697472⟩
Share
Metrics
Record views
171
