Component Software: Beyond Object-Oriented Programming, 2002. ,
On High Performance Composition Operators in Component Models. High Performance Scientific Computing with special emphasis on Current Capabilities and Future Perspectives, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00626698
Improving Memory Affinity of Geophysics Applications on NUMA Platforms Using Minas. High Performance Computing for Computational Science ? VECPAR 2010, pp.279-292, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00788872
Using MPI: Portable Parallel Programming with the Message-Passing Interface, 1999. ,
Near-optimal placement of MPI processes on hierarchical NUMA architectures. Euro-Par'10, pp.199-210, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00544346
MPICH-G2: A Grid-enabled implementation of the Message Passing Interface, Journal of Parallel and Distributed Computing, vol.63, issue.5, pp.551-563, 2003. ,
DOI : 10.1016/S0743-7315(03)00002-9
Programming with POSIX threads, 1997. ,
Ruud van derUsing OpenMP: Portable Shared Memory Parallel Programming (Scientific and Engineering Computation ), 2007. ,
OpenMP to GPGPU: a compiler framework for automatic translation and optimization, Proceedings of the 14th ACM SIGPLAN symposium on Principles and practice of parallel programming(PPoPP '09), pp.101-110, 2009. ,
Programming Petascale Applications with Charm++ and AMPI. Petascale Computing: Algorithms and Applications, pp.421-441, 2008. ,
An evaluation of global address space languages, Proceedings of the tenth ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '05, pp.36-47, 2005. ,
DOI : 10.1145/1065944.1065950
OSGi Service Platform Specifications Available at http://www.osgi. or [13] Mozilla. The XPCom projet ,
UNO Component Model Available at http://www.openoffice.org/ udk/common/man/componentmodel.html [15] Object Management Group,Common Object Request Broker Architecture Specification, Version 3.1, Part 3: CORBA Component Model, 2008. ,
GCM: A Grid Extension to F RACTAL for Autonomous Distributed Components. Special Issue of Annals of Telecommunications: Software Components ? The Fractal Initiative, p.5, 2009. ,
A Component Architecture for High-Performance Scientific Computing, International Journal of High Performance Computing Applications, vol.20, issue.2, pp.163-202, 2006. ,
DOI : 10.1177/1094342006064488
Enabling Connectors in Hierarchical Component Models, 2010. ,
URL : https://hal.archives-ouvertes.fr/ensl-00456961
NEMO ocean engine, Note du Pole de modélisation, 2008. ,
Inovallée 655 avenue de l'Europe Montbonnot 38334 Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria, pp.249-6399 ,
