Mancoosi Deliverable D5.3: UPDB infrastructure to collect traces of upgradeability problems in CUDF format - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Pietro Abate
  • Fonction : Auteur
  • PersonId : 860627
Ralf Treinen
  • Fonction : Auteur
  • PersonId : 845934
One of the objectives of the Mancoosi project is to resolve some of the problems that users of Free and Open Source Software distributions experience when trying to install, remove, or upgrade packages installed on their machines. The specific goal of Workpackage 5 is to to build a data base of problem reports generated from such user requests to a meta-installer, which then will be used by the Mancoosi project, and the research community in general, to develop better algorithms to compute upgrade paths.
d5.3.pdf (392.76 Ko) Télécharger le fichier
hal-00698968 , version 1 (18-05-2012)
  • HAL Id : hal-00698968 , version 1
Pietro Abate, Ralf Treinen. Mancoosi Deliverable D5.3: UPDB infrastructure to collect traces of upgradeability problems in CUDF format. [Research Report] 2011. ⟨hal-00698968⟩
68 Consultations
55 Téléchargements
