Constraint Reasoning in FocalTest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Property-based testing implies selecting test data satisfying coverage criteria on user-specified properties. However, current automatic test data generation techniques adopt direct generate-and-test approaches for this task. In FocalTest, a testing tool designed to generate test data for programs and properties written in the functionnal language Focal, test data are generated at random and rejected when they do not satisfy selected coverage criteria. In this paper, we improve FocalTest with a test-and-generate approach, through the usage of constraint reasoning. A particular difficulty is the generation of test data satisfying MC/DC on the precondition of a property, when it contains function calls with pattern matching and higher-order functions. Our experimental results show that a non-naive implementation of constraint reasoning on these constructions outperform traditional generation techniques when used to find test data for testing properties.
paper.pdf (108.6 Ko) Télécharger le fichier
hal-00699233 , version 1 (20-05-2012)
  • HAL Id : hal-00699233 , version 1
Mathieu Carlier, Catherine Dubois, Arnaud Gotlieb. Constraint Reasoning in FocalTest. ICSOFT, Jul 2010, Athènes, Greece. ⟨hal-00699233⟩
218 Consultations
222 Téléchargements
