On MMSE and MAP Denoising Under Sparse Representation Modeling Over a Unitary Dictionary
Abstract : Among the many ways to model signals, a recent approach that draws considerable attention is sparse representation modeling. In this model, the signal is assumed to be generated as a random linear combination of a few atoms from a prespecified dictionary. In this work, two Bayesian denoising algorithms are analyzed for this model-the maximum a posteriori probability (MAP) and the minimum-mean-squared-error (MMSE) estimators, both under the assumption that the dictionary is unitary. It is well known that both these estimators lead to a scalar shrinkage on the transformed coefficients, albeit with a different response curve. We derive explicit expressions for the estimation-error for these two estimators. Upper bounds on these errors are developed and tied to the expected error of the so-called oracle estimator, for which the support is assumed to be known. This analysis establishes a worst-case gain-factor between the MAP/MMSE estimation errors and that of the oracle.
Type de document :
Article dans une revue
IEEE Transactions on Signal Processing, Institute of Electrical and Electronics Engineers, 2011, 59 (8), pp.3526 -3535. 〈10.1109/TSP.2011.2151190〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00700284
Contributeur : Jules Espiau de Lamaestre <>
Soumis le : mardi 22 mai 2012 - 15:58:24
Dernière modification le : samedi 14 avril 2018 - 23:58:03
Citation
Javier S. Turek, I. Yavneh, Michael Elad. On MMSE and MAP Denoising Under Sparse Representation Modeling Over a Unitary Dictionary. IEEE Transactions on Signal Processing, Institute of Electrical and Electronics Engineers, 2011, 59 (8), pp.3526 -3535. 〈10.1109/TSP.2011.2151190〉. 〈hal-00700284〉
Métriques
Consultations de la notice
73
