Separating sources from sequentially acquired mixtures of heart signals
In this paper, we consider the problem of separating a set of independent components when only one movable sensor is available to record the mixtures. We propose to exploit the quasi-periodicity of the heart signals to transform the signal from this one moving sensor, into a set of measurements, as if from a virtual array of sensors. We then use ICA to perform source separation. We show that this technique can be applied to heart sounds and to electrocardiograms.
