The decoding Library for List Decoding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
The decoding library is a C library whose main goal is to implement as effi- ciently as possible the Guruswami-Sudan algorithm. It is written in C89 and is stand-alone.
abstract.pdf (53.02 Ko) Télécharger le fichier
hal-00700397 , version 1 (22-05-2012)
hal-00700397 , version 2 (06-06-2012)
  • HAL Id : hal-00700397 , version 1
Guillaume Quintin. The decoding Library for List Decoding. 2012. ⟨hal-00700397v1⟩
158 Consultations
331 Téléchargements
