The Magma Algebra System I: The User Language, Computational algebra and number theory, pp.3-4235, 1993. ,
DOI : 10.1006/jsco.1996.0125
Polynomial root finding over local rings and application to error correcting codes, Applicable Algebra in Engineering, Communication and Computing, vol.69, issue.231, 2011. ,
DOI : 10.1007/s00200-013-0200-5
URL : https://hal.archives-ouvertes.fr/hal-00642075
A New Algorithm for Decoding Reed-Solomon Codes, Communications, Information, pp.55-68, 2002. ,
DOI : 10.1007/978-1-4757-3789-9_5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.368
Software available from http, 2007. ,
The GNU Multiple Precision Arithmetic Library, 1991. ,
Improved decoding of Reed-Solomon and algebraic-geometric codes, Proceedings 39th Annual Symposium on Foundations of Computer Science (Cat. No.98CB36280), pp.1757-1767, 1998. ,
DOI : 10.1109/SFCS.1998.743426
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.146.2065
MPFQ : Fast Finite fields, 2006. ,
Software available from http, 2002. ,
Fast Library for Number Theory: An Introduction, Mathematical Software ICMS 2010, pp.88-91, 2010. ,
On the complexity of decoding Reed-Solomon codes (Corresp.), IEEE Trans. Inform. Theory, vol.22, issue.2, pp.237-238, 1976. ,
The Guruswami-Sudan Decoding Algorithm for Reed-Solomon Codes, 2003. ,
Codes Over Matrix Rings for Space-Time Coded Modulations, IEEE Transactions on Information Theory, vol.58, issue.2, pp.734-746, 2012. ,
DOI : 10.1109/TIT.2011.2173732
URL : http://arxiv.org/abs/1008.1387
Efficient decoding of Reed-Solomon codes beyond half the minimum distance, In IEEE Trans. Inform. Theory, p.56, 1998. ,
Polynomial Codes Over Certain Finite Fields, Journal of the Society for Industrial and Applied Mathematics, vol.8, issue.2, pp.300-304, 1960. ,
DOI : 10.1137/0108018
NTL: A Library for doing Number Theory, 1990. ,
Decoding Reed-Solomon codes beyond the error-correction diameter, the 35th Annual Allerton Conference on Communication, Control and Computing, pp.215-224, 1997. ,
DOI : 10.1006/jcom.1997.0439
URL : http://doi.org/10.1006/jcom.1997.0439
Reed-Solomon Codes and Their Applications, 1999. ,
DOI : 10.1109/9780470546345
