auteur tient à remercier ici tous ceux qui l'ont aidé dans l'exploration de cette théorie, en premier lieu T, ainsi que les très nombreuses personnes avec lesquelles il a échangé au cours de visites, conférences et séminaires ,
Flows driven by rough paths, Revista Matem??tica Iberoamericana, vol.31, issue.3, 2012. ,
DOI : 10.4171/RMI/858
URL : https://hal.archives-ouvertes.fr/hal-00704959
An Introduction to the Geometry of Stochastic Flows, 2004. ,
The Magnus expansion and some of its applications, Physics Reports, vol.470, issue.5-6, pp.151-238, 2009. ,
DOI : 10.1016/j.physrep.2008.11.001
Integration of paths???a faithful representation of paths by non-commutative formal power series, Transactions of the American Mathematical Society, vol.89, issue.2, pp.395-407, 1958. ,
DOI : 10.1090/S0002-9947-1958-0106258-0
Stochastic analysis, rough path analysis and fractional Brownian motions, Probability Theory and Related Fields, vol.122, issue.1, pp.108-140, 2002. ,
DOI : 10.1007/s004400100158
URL : https://hal.archives-ouvertes.fr/hal-00266874
Differential Equations Driven by Rough Signals : an Approach via Discrete Approximation, Appl. Math. Res. Express. AMRX, vol.2, p.40, 2007. ,
A non-commutative sewing lemma, Electronic Communications in Probability, vol.13, issue.0, pp.24-34, 2008. ,
DOI : 10.1214/ECP.v13-1345
URL : https://hal.archives-ouvertes.fr/hal-00151183
Curvilinear integrals along enriched paths, Electron, J. Probab, vol.11, issue.34, pp.860-892, 2006. ,
Multidimensional Stochastic Processes as Rough Paths Theory and Applications A note on the notion of geometric rough paths, Probab. Theory Related Fields, vol.10, issue.136 3, pp.395-416, 2006. ,
Variable step size control in the numerical solution of stochastic differential equations, SIAM J. Appl. Math, vol.57, issue.5, pp.1455-1484, 1997. ,
Controlling rough paths, Journal of Functional Analysis, vol.216, issue.1, pp.86-140, 2004. ,
DOI : 10.1016/j.jfa.2004.01.002
URL : http://doi.org/10.1016/j.jfa.2004.01.002
Solving the KPZ equation, 2011. ,
Large deviations and support theorem for diffusion processes via rough paths, Stochastic Process, Appl, vol.102, issue.2, pp.265-283, 2002. ,
Controlled differential equations as Young integrals: A simple approach, Yet another introduction to rough paths, pp.215-246, 2009. ,
DOI : 10.1016/j.jde.2010.05.006
URL : https://hal.archives-ouvertes.fr/inria-00402397
On <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mi>p</mml:mi><mml:mo>,</mml:mo><mml:mi>q</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-rough paths, Journal of Differential Equations, vol.225, issue.1, pp.103-133, 2006. ,
DOI : 10.1016/j.jde.2006.01.018
An Introduction to Rough Paths, Lecture Notes in Math, vol.1832, pp.1-59, 2003. ,
DOI : 10.1007/978-3-540-40004-2_1
URL : https://hal.archives-ouvertes.fr/inria-00102184
Differential equations driven by rough signals, Revista Matem??tica Iberoamericana, vol.14, issue.2, pp.215-310, 1998. ,
DOI : 10.4171/RMI/240
Differential Equations Driven by Rough Paths, École d'été des probabilités de Saint-Flour XXXIV ?, Lecture Notes in Math, vol.1908, 2004. ,
System Control and Rough Paths, 2002. ,
An extension theorem to rough paths, Cubature on Wiener space, pp.835-847, 2004. ,
DOI : 10.1016/j.anihpc.2006.07.004
From Constructive Field Theory to Fractional Stochastic Calculus. (I) An introduction: Rough Path Theory and Perturbative Heuristics, Annales Henri Poincar??, vol.36, issue.1, pp.1199-1226, 2011. ,
DOI : 10.1007/s00023-011-0106-3
URL : https://hal.archives-ouvertes.fr/hal-00491768
Convergence of Multi-Dimensional Quantized SDE???s, Lecture Notes in Math, vol.2006, pp.269-307, 2011. ,
DOI : 10.1007/978-3-642-15217-7_11
Aspects de la théorie des chemins rugueux, Gazette des mathématiciens, vol.131, pp.16-33, 2012. ,
An inequality of the H??lder type, connected with Stieltjes integration, Acta Mathematica, vol.67, issue.0, pp.251-282, 1936. ,
DOI : 10.1007/BF02401743
