The accuracy of tomographic particle image velocimetry for measurements of a turbulent boundary layer
Abstract : To investigate the accuracy of tomographic particle image velocimetry (Tomo-PIV) for turbulent boundary layer measurements, a series of synthetic image-based simulations and practical experiments are performed on a high Reynolds number turbulent boundary layer at Reθ = 7,800. Two different approaches to Tomo-PIV are examined using a full-volume slab measurement and a thin-volume "fat" light sheet approach. Tomographic reconstruction is performed using both the standard MART technique and the more efficient MLOS-SMART approach, showing a 10-time increase in processing speed. Random and bias errors are quantified under the influence of the near-wall velocity gradient, reconstruction method, ghost particles, seeding density and volume thickness, using synthetic images. Experimental Tomo-PIV results are compared with hot-wire measurements and errors are examined in terms of the measured mean and fluctuating profiles, probability density functions of the fluctuations, distributions of fluctuating divergence through the volume and velocity power spectra. Velocity gradients have a large effect on errors near the wall and also increase the errors associated with ghost particles, which convect at mean velocities through the volume thickness. Tomo-PIV provides accurate experimental measurements at low wave numbers; however, reconstruction introduces high noise levels that reduces the effective spatial resolution. A thinner volume is shown to provide a higher measurement accuracy at the expense of the measurement domain, albeit still at a lower effective spatial resolution than planar and Stereo-PIV.
Type de document :
Communication dans un congrès
Eighth International Symposium on Particle Image Velocimetry, Aug 2009, Melbourne, Australia. 2009, 〈10.1007/s00348-010-1004-z〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00701461
Contributeur : Ist Rennes <>
Soumis le : vendredi 25 mai 2012 - 14:31:22
Dernière modification le : jeudi 5 avril 2018 - 10:04:03
Lien texte intégral
Collections
Citation
Callum Atkinson, Sébastien Coudert, Jean-Marc Foucaut, Michel Stanislas, Julio Soria. The accuracy of tomographic particle image velocimetry for measurements of a turbulent boundary layer. Eighth International Symposium on Particle Image Velocimetry, Aug 2009, Melbourne, Australia. 2009, 〈10.1007/s00348-010-1004-z〉. 〈hal-00701461〉
Métriques
Consultations de la notice
125
