Numerical simulation of blood flows through a porous interface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2008
We propose a model for a medical device, called a stent, designed for the treatment of cerebral aneurysms. The stent consists of a grid, immersed in the blood flow and located at the inlet of the aneurysm. It aims at promoting a clot within the aneurysm. The blood flow is modelled by the incompressible Navier-Stokes equations and the stent by a dissipative surface term. We propose a stabilized finite element method for this model and we analyse its convergence in the case of the Stokes equations. We present numerical results for academical test cases, and on a realistic aneurysm obtained from medical imaging.
hal-00701783 , version 1 (26-05-2012)
Miguel Angel Fernández, Jean-Frédéric Gerbeau, Vincent Martin. Numerical simulation of blood flows through a porous interface. ESAIM: Mathematical Modelling and Numerical Analysis, 2008, 42 (6), pp.961-990. ⟨10.1051/m2an:2008031⟩. ⟨hal-00701783⟩
187 Consultations
0 Téléchargements
