Reaching approximate agreement in the presence of faults, Proc. of 3rd IEEE Symp. on Reliability in Distributed Software and Database Systems, pp.145-154, 1983. ,
DOI : 10.1145/5925.5931
Optimal Resilience Asynchronous Approximate Agreement, Proc. of the 8th Int. Conf. on Principles of Distributed Systems, pp.229-239, 2005. ,
DOI : 10.1007/11516798_17
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.76.3425
Distributed function calculation via linear iterations in the presence of malicious agents — Part I: Attacking the network, 2008 American Control Conference, pp.1350-1355, 2008. ,
DOI : 10.1109/ACC.2008.4586680
Distributed function calculation via linear iterations in the presence of malicious agents — Part II: Overcoming malicious behavior, 2008 American Control Conference, pp.1356-1361, 2008. ,
DOI : 10.1109/ACC.2008.4586681
Consensus Computation in Unreliable Networks: A System Theoretic Approach, IEEE Transactions on Automatic Control, vol.57, issue.1, pp.90-104, 2012. ,
DOI : 10.1109/TAC.2011.2158130
A survey of consensus problems in multi-agent coordination, Proc. of American Control Conference, pp.1859-1864, 2005. ,
Iterative approximate byzantine consensus in arbitrary directed graphs, Proceedings of the 2012 ACM symposium on Principles of distributed computing, PODC '12, 2012. ,
DOI : 10.1145/2332432.2332505
Robustness of information diffusion algorithms to locally bounded adversaries. CoRR, abs, 1110. ,
Consensus of multi-agent networks in the presence of adversaries using only local information, Proceedings of the 1st international conference on High Confidence Networked Systems, HiCoNS '12, pp.1-10, 2012. ,
DOI : 10.1145/2185505.2185507
Coordination of groups of mobile autonomous agents using nearest neighbor rules, IEEE Transactions on Automatic Control, vol.48, issue.6, pp.988-1001, 2003. ,
DOI : 10.1109/TAC.2003.812781
A step toward global convergence in partially connected networks, Proc. of Conf. on Parallel and Distributed Computing Systems, pp.234-241, 1997. ,
Global convergence in partially fully connected networks (pfcn) with limited relays, Proc. of the 27th Conf. of the IEEE Industrial Electronics Society, pp.2022-2025, 2001. ,
Consensus seeking in multiagent systems under dynamically changing interaction topologies, IEEE Transactions on Automatic Control, vol.50, issue.5, pp.655-661, 2005. ,
DOI : 10.1109/TAC.2005.846556
On Maximizing the Second Smallest Eigenvalue of a State-Dependent Graph Laplacian, IEEE Transactions on Automatic Control, vol.51, issue.1, pp.116-120, 2006. ,
DOI : 10.1109/TAC.2005.861710
The bg-simulation for byzantine mobile robots, Proc. of DISC, pp.330-331, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01285672
