A computational fluid mechanics solution to the Monge-Kantorovich mass transfer problem, Numerische Mathematik, vol.84, issue.3, pp.375-393, 2000. ,
DOI : 10.1007/s002110050002
Mixed L 2-Wasserstein Optimal Mapping Between Prescribed Density Functions, Journal of Optimization Theory and Applications, vol.44, issue.2, pp.255-271, 2001. ,
DOI : 10.1023/A:1011926116573
Convex analysis and optimization With Angelia Nedi´cNedi´c and Asuman E. Ozdaglar. MR2184037 (2006j:90001) [Ber92] , Auction algorithms for network flow problems: a tutorial introduction, Athena Scientific Comput. Optim. Appl, vol.193, issue.1, pp.7-66, 1992. ,
Numerical Approximation of Optimal Transport Maps, SSRN Electronic Journal, 2010. ,
DOI : 10.2139/ssrn.1730684
Polar factorization and monotone rearrangement of vector-valued functions, Communications on Pure and Applied Mathematics, vol.117, issue.4, pp.375-417, 1991. ,
DOI : 10.1002/cpa.3160440402
Convergence of approximation schemes for fully nonlinear second order equations, Asymptotic Anal, pp.271-28335137, 1991. ,
Convex optimization, p.206157590002, 2004. ,
Moving Mesh Generation Using the Parabolic Monge???Amp??re Equation, SIAM Journal on Scientific Computing, vol.31, issue.5, pp.3438-3465, 2009. ,
DOI : 10.1137/080716773
Boundary regularity of maps with convex potentials. II, Ann. of Math, issue.2 3, pp.144-453, 1996. ,
Robust, multidimensional mesh-motion based on Monge???Kantorovich equidistribution, Journal of Computational Physics, vol.230, issue.1, pp.87-103, 2011. ,
DOI : 10.1016/j.jcp.2010.09.013
Numerical Simulation of Diffusive and Aggregation Phenomena in Nonlinear Continuity Equations by Evolving Diffeomorphisms, SIAM Journal on Scientific Computing, vol.31, issue.6, pp.4305-4329, 2009. ,
DOI : 10.1137/080739574
Generalised Lagrangian Solutions for Atmospheric and Oceanic Flows, SIAM Journal on Applied Mathematics, vol.51, issue.1, pp.20-31, 1991. ,
DOI : 10.1137/0151002
An extended Lagrangian theory of semigeostrophic frontogenesis, J. Atmospheric Sci, vol.4187, issue.9, pp.1477-1497, 1984. ,
On the computation of optimal transport maps using gradient flows and multiresolution analysis , Recent advances in learning and control, pp.65-78, 2008. ,
Classical solvability in dimension two of the second boundary-value problem associated with the Monge-Amp??re operator, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.8, issue.5, pp.443-457, 1991. ,
DOI : 10.1016/S0294-1449(16)30256-6
A reconstruction of the initial conditions of the Universe by optimal mass transportation, Nature, vol.34, issue.6886, 2002. ,
DOI : 10.1086/176348
Convergent finite difference solvers for viscosity solutions of the elliptic Monge-Ampère equation in dimensions two and higher MR2831067 [FO11b] , Fast finite difference solvers for singular solutions of the elliptic Monge-Ampère equation, SIAM J. Numer. Anal. J. Comput. Phys, vol.49, issue.4 3, pp.1692-1714, 2011. ,
A Numerical Method for the Elliptic Monge--Amp??re Equation with Transport Boundary Conditions, SIAM Journal on Scientific Computing, vol.34, issue.3, pp.1432-1459, 2012. ,
DOI : 10.1137/110822372
Optical design of single reflector systems and the Monge-Kantorovich mass transfer problem Nonlinear problems and function theory. MR2027449 (2004k:49101) [GO03b] , Optical design of single reflector systems and the Monge-Kantorovich mass transfer problem, Journal of Mathematical Sciences, vol.117, issue.3, pp.4096-4108, 2003. ,
DOI : 10.1023/A:1024856201493
An Efficient Numerical Method for the Solution of the $L_2$ Optimal Mass Transfer Problem, SIAM Journal on Scientific Computing, vol.32, issue.1, pp.197-211, 2010. ,
DOI : 10.1137/080730238
Optimal Mass Transport for Registration and Warping, International Journal of Computer Vision, vol.60, issue.3, pp.225-240, 2004. ,
DOI : 10.1023/B:VISI.0000036836.66311.97
The Variational Formulation of the Fokker--Planck Equation, SIAM Journal on Mathematical Analysis, vol.29, issue.1, pp.1-17, 1998. ,
DOI : 10.1137/S0036141096303359
On the transfer of masses, Dokl. Akad. Nauk. SSSR, vol.378, issue.7, pp.227-229, 1942. ,
Approximation of Parabolic Equations Using the Wasserstein Metric, ESAIM: Mathematical Modelling and Numerical Analysis, vol.33, issue.4, pp.837-852, 1999. ,
DOI : 10.1051/m2an:1999166
Numerical solution of the Monge???Amp??re equation by a Newton's algorithm, Comptes Rendus Mathematique, vol.340, issue.4, pp.319-324, 2005. ,
DOI : 10.1016/j.crma.2004.12.018
COMPUTATION OF MEAN FIELD EQUILIBRIA IN ECONOMICS, Mathematical Models and Methods in Applied Sciences, vol.20, issue.04, pp.567-588, 2010. ,
DOI : 10.1142/S0218202510004349
URL : https://hal.archives-ouvertes.fr/hal-00346214
The neumann problem for equations of monge-amp??re type, Communications on Pure and Applied Mathematics, vol.20, issue.4, pp.539-563, 1986. ,
DOI : 10.1002/cpa.3160390405
A Multiscale Approach to Optimal Transport, Computer Graphics Forum, vol.40, issue.2, pp.1583-1592, 2011. ,
DOI : 10.1111/j.1467-8659.2011.02032.x
URL : https://hal.archives-ouvertes.fr/hal-00604684
Exact semi-geostrophic flows in an elliptical ocean basin, Nonlinearity, vol.17, issue.5, pp.1891-1922, 2004. ,
Handling congestion in crowd motion modeling On the approximation of linear elliptic differential equations by difference equations with positive coefficients, MR2826756 [MW53] Theodore S. Motzkin and Wolfgang Wasow, pp.485-519, 1953. ,
A convergent monotone difference scheme for motion of level sets by mean curvature, Numer. Math, vol.99, issue.2, pp.365-379, 2004. ,
The dirichlet problem for the convex envelope, Trans. Amer. Math. Soc, issue.16, 2009. ,
THE GEOMETRY OF DISSIPATIVE EVOLUTION EQUATIONS: THE POROUS MEDIUM EQUATION, Communications in Partial Differential Equations, vol.4, issue.1-2, pp.101-174, 2001. ,
DOI : 10.1007/BF00535689
Generalized solutions of Monge-Ampère equations of elliptic type, A tribute to Ilya Bakelman (College Station, TX Numerical and analytical results for the transportation problem of Monge-Kantorovich, MR1423367 [RU00] Ludger Rüschendorf and Ludger Uckelmann, pp.47-50, 1993. ,
On the second boundary value problem for equations of Monge- Ampère type, J. Reine Angew. Math, vol.487, pp.115-124, 1997. ,
