Targeting of observations for accidental atmospheric release monitoring, Atmospheric Environment, vol.43, issue.40, pp.6312-6327, 2009. ,
DOI : 10.1016/j.atmosenv.2009.09.029
URL : https://hal.archives-ouvertes.fr/inria-00567404
An adaptive covariance inflation error correction algorithm for ensemble filters, pp.210-224, 2007. ,
Reconstruction of an atmospheric tracer source using the principle of maximum entropy. I: Theory, Quarterly Journal of the Royal Meteorological Society, vol.105, issue.610, pp.2191-2208, 2005. ,
DOI : 10.1256/qj.04.67
URL : https://hal.archives-ouvertes.fr/inria-00527210
Parameter-field estimation for atmospheric dispersion: application to the Chernobyl accident using 4D-Var, Quarterly Journal of the Royal Meteorological Society, vol.113, issue.664, 2012. ,
DOI : 10.1002/qj.961
URL : https://hal.archives-ouvertes.fr/hal-00705045
Beyond Gaussian Statistical Modeling in Geophysical Data Assimilation, Beyond Gaussian statistical modeling in geophysical data assimilation, pp.2997-3023, 2010. ,
DOI : 10.1175/2010MWR3164.1
URL : https://hal.archives-ouvertes.fr/inria-00538648
Modelling transport and deposition of caesium and iodine from the Chernobyl accident using the DREAM model, Atmospheric Chemistry and Physics, vol.2, issue.5, pp.397-417, 2002. ,
DOI : 10.5194/acp-2-397-2002
URL : https://hal.archives-ouvertes.fr/hal-00295217
Properties and first application of an error-statistics tuning method in variational assimilation, Quarterly Journal of the Royal Meteorological Society, vol.123, issue.601, pp.2253-2275, 2004. ,
DOI : 10.1256/qj.03.26
Diagnosis and tuning of observational error in a quasi-operational data assimilation setting, Quarterly Journal of the Royal Meteorological Society, vol.123, issue.615, pp.543-565, 2006. ,
DOI : 10.1256/qj.04.102
Cs Accidentally Discharged from the Fukushima Daiichi Nuclear Power Plant into the Atmosphere, Journal of Nuclear Science and Technology, vol.45, issue.9, pp.1129-1134, 2011. ,
DOI : 10.1080/18811248.2011.9711799
Inverse modelling-based reconstruction of the Chernobyl source term available for long-range transport, Atmospheric Chemistry and Physics, vol.7, issue.6, pp.1549-1564, 2007. ,
DOI : 10.5194/acp-7-1549-2007
URL : https://hal.archives-ouvertes.fr/hal-00328489
On-line Estimation of Error Covariance Parameters for Atmospheric Data Assimilation, Monthly Weather Review, vol.123, issue.4, pp.1128-1145, 1995. ,
DOI : 10.1175/1520-0493(1995)123<1128:OLEOEC>2.0.CO;2
Bayesian Inference and Markov Chain Monte Carlo Sampling to Reconstruct a Contaminant Source on a Continental Scale, Journal of Applied Meteorology and Climatology, vol.47, issue.10, pp.2600-2613, 2008. ,
DOI : 10.1175/2008JAMC1766.1
Diagnosis and adaptive tuning of observation-error parameters in a variational assimilation, Quarterly Journal of the Royal Meteorological Society, vol.108, issue.574, pp.1433-1452, 2001. ,
DOI : 10.1002/qj.49712757417
Emission rate and chemical state estimation by 4-dimensional variational inversion, Atmospheric Chemistry and Physics, vol.7, issue.14, pp.3749-3769, 2007. ,
DOI : 10.5194/acp-7-3749-2007
URL : https://hal.archives-ouvertes.fr/hal-00328512
Inverse Problems in Atmospheric Constituent Transport, 2002. ,
DOI : 10.1017/CBO9780511535741
Simulation of multivariate normal rectangle probabilities and their derivatives theoretical and computational results, Journal of Econometrics, vol.72, issue.1-2, pp.85-134, 1996. ,
DOI : 10.1016/0304-4076(94)01716-6
Analysis of Discrete Ill-Posed Problems by Means of the L-Curve, SIAM Review, vol.34, issue.4, pp.561-580, 1992. ,
DOI : 10.1137/1034115
Probing ETEX-II data set with inverse modelling, Atmospheric Chemistry and Physics, vol.8, issue.14, pp.3963-3971, 2008. ,
DOI : 10.5194/acp-8-3963-2008
URL : https://hal.archives-ouvertes.fr/hal-00328305
A truncated Gaussian filter for data assimilation with inequality constraints: Application to the hydrostatic stability condition in ocean models, Ocean Modelling, vol.27, issue.1-2, pp.1-17, 2009. ,
DOI : 10.1016/j.ocemod.2008.10.007
Simultaneous estimation of covariance inflation and observation errors within an ensemble Kalman filter, Quarterly Journal of the Royal Meteorological Society, vol.134, issue.639, pp.523-533, 2009. ,
DOI : 10.1002/qj.371
A parametric model of vertical eddy fluxes in the atmosphere, Boundary-Layer Meteorology, vol.93, issue.2, pp.197-202, 1979. ,
DOI : 10.1007/BF00117978
Assimilation of Stratospheric Chemical Tracer Observations Using a Kalman Filter. Part I: Formulation, Monthly Weather Review, vol.128, issue.8, pp.2654-2671, 2000. ,
DOI : 10.1175/1520-0493(2000)128<2654:AOSCTO>2.0.CO;2
A geostatistical approach to surface flux estimation of atmospheric trace gases, Journal of Geophysical Research, vol.34, issue.6, pp.10-1029, 2004. ,
DOI : 10.1029/2003JD004422
An Adaptive Ensemble Kalman Filter, An adaptive ensemble Kalman filter, pp.416-433, 1999. ,
DOI : 10.1175/1520-0493(2000)128<0416:AAEKF>2.0.CO;2
Simulation of the Chernobyl dispersion with a 3-D hemispheric tracer model, pp.391-412, 1989. ,
Validation of the Polyphemus platform on the ETEX, Chernobyl and Algeciras cases, Validation of the Polyphemus platform on the ETEX, Chernobyl and Algeciras cases, pp.5300-5315, 2007. ,
DOI : 10.1016/j.atmosenv.2007.02.035
Simulation of truncated normal variables, Statistics and Computing, vol.82, issue.2, pp.121-125, 1995. ,
DOI : 10.1007/BF00143942
URL : https://hal.archives-ouvertes.fr/hal-00431310
Constraining surface emissions of air pollutants using inverse modeling: Method intercomparison and a new two-step multiscale approach, pp.360-370, 2011. ,
Xenon-133 and caesium- 137 releases into the atmosphere from the Fukushima Dai-ichi nuclear power plant: Determination of the source term, atmospheric dispersion, and deposition, Atmos. Chem. Phys. Discuss, vol.11, issue.28, pp.319-28394, 2011. ,
Inverse modeling of European CH<sub>4</sub> emissions: sensitivity to the observational network, Inverse modeling of European CH 4 emissions: Sensitivity to the observational network, pp.1249-1267, 2010. ,
DOI : 10.5194/acp-10-1249-2010
Spline Models for Observational Data, Conf. Ser. Appl. Math. Soc. for Ind. and Appl. Math, vol.59, issue.180, 1990. ,
DOI : 10.1137/1.9781611970128
Towards the operational estimation of a radiological plume using data assimilation after a radiological accidental atmospheric release, Atmospheric Environment, vol.45, issue.17, pp.2944-2955, 2011. ,
DOI : 10.1016/j.atmosenv.2010.12.025
URL : https://hal.archives-ouvertes.fr/inria-00632440
Optimal representation of source-sink fluxes for mesoscale carbon dioxide inversion with synthetic data, Journal of Geophysical Research: Atmospheres, vol.8, issue.22, pp.10-1029, 2011. ,
DOI : 10.1029/2010JD014887
URL : https://hal.archives-ouvertes.fr/hal-00646748
Bayesian inversion of concentration data: Source reconstruction in the adjoint representation of atmospheric diffusion, Journal of Wind Engineering and Industrial Aerodynamics, vol.96, issue.10-11, pp.1805-1816, 2008. ,
DOI : 10.1016/j.jweia.2008.02.024
Institute of Radiation Protection and Nuclear Safety ,
