A Newton method using exact jacobians for solving fluid-structure coupling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers & Structures Année : 2005
This paper aims at introducing a partitioned Newton based method for solving nonlinear coupled systems arising in the numerical approximation of fluid-structure interaction problems. We provide a method which characteristic lies in the use of exact cross Jacobians evaluation involving the shape derivative of the fluid state with respect to solid motion perturbations. Numerical tests based on an implementation inside a 3D fluid-structure interaction code show how the exactness of the cross Jacobians computation guarantee the overall convergence of the Newton's loop.
hal-00705110 , version 1 (06-06-2012)
Miguel Angel Fernández, Marwan Moubachir. A Newton method using exact jacobians for solving fluid-structure coupling. Computers & Structures, 2005, 83 (2-3), pp.127-142. ⟨10.1016/j.compstruc.2004.04.021⟩. ⟨hal-00705110⟩
162 Consultations
0 Téléchargements
