An exact Block-Newton algorithm for the solution of implicit time discretized coupled systems involved in fluid-structure interaction problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2003
In this Note, we introduce a partitioned Newton based method for solving nonlinear coupled systems arising in the numerical approximation of fluid-structure interaction problems. The originality of this Schur-Newton algorithm lies in the exact Jacobians evaluation involving the fluid-structure linearized subsystems which are here fully developed.
hal-00705112 , version 1 (06-06-2012)
Miguel Angel Fernández, Marwan Moubachir. An exact Block-Newton algorithm for the solution of implicit time discretized coupled systems involved in fluid-structure interaction problems. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2003, 336, pp.681-686. ⟨10.1016/S1631-073X(03)00151-1⟩. ⟨hal-00705112⟩
202 Consultations
0 Téléchargements
