New interface
Journal articles
Acceleration of a fixed point algorithm for fluid-structure interaction using transpiration conditions
Simone Deparis 1 Miguel Angel Fernández 2 Luca Formaggia 1
2 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : In this work, we address the numerical solution of fluid-structure interaction problems. This issue is particularly difficulty to tackle when the fluid and the solid densities are of the same order, for instance as it happens in hemodynamic applications, since fully implicit coupling schemes are required to ensure stability of the resulting method. Thus, at each time step, we have to solve a highly non-linear coupled system, since the fluid domain depends on the unknown displacement of the structure. Standard strategies for solving this non-linear problems, are fixed point based methods such as Block-Gauss-Seidel (BGS) iterations. Unfortunately, these methods are very CPU time consuming and usually show slow convergence. We propose a modified fixed-point algorithm which combines the standard BGS iterations with a transpiration formulation. Numerical experiments show the great improvement in computing time with respect to the standard BGS method.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00705114
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Wednesday, June 6, 2012 - 7:20:49 PM
Last modification on : Friday, January 21, 2022 - 3:21:15 AM
Links full text
Identifiers
Citation
Simone Deparis, Miguel Angel Fernández, Luca Formaggia. Acceleration of a fixed point algorithm for fluid-structure interaction using transpiration conditions. ESAIM: Mathematical Modelling and Numerical Analysis, 2003, 37 (4), pp.601-616. ⟨10.1051/m2an:2003050⟩. ⟨hal-00705114⟩
Share
Metrics
Record views
143
