Linear stability analysis in fluid-structure interaction with transpiration. Part II: Numerical analysis and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2003
This paper constitutes the numerical counterpart of the mathematical framework introduced in Part I. We address the problem of flutter analysis of a coupled fluid-structure system involving an incompressible Newtonian fluid and a reduced structure. We use the Linearization Principle approach developed in Part I, particularly suited for fluid-structure problems involving moving boundaries. Thus, the stability analysis is reduced to the computation of the leftmost eigenvalues of a coupled eigenproblem of minimal complexity. This eigenproblem involves the linearized incompressible Navier-Stokes equations and those of a reduced linear structure. The coupling is realized through specific transpiration interface conditions. The eigenproblem is discretized using a finite element approximation and its smallest real part eigenvalues are computed by combining a generalized Cayley transform and an implicit restarted Arnoldi method. Finally, we report three numerical experiments : a structure immersed in a fluid at rest, a cantilever pipe conveying a fluid flow and a rectangular bridge deck profile under wind effects. The numerical results are compared to former approaches and experimental data. The quality of these numerical results is very satisfactory and promising.
hal-00705123 , version 1 (06-06-2012)
Miguel Angel Fernández, Patrick Le Tallec. Linear stability analysis in fluid-structure interaction with transpiration. Part II: Numerical analysis and applications. Computer Methods in Applied Mechanics and Engineering, 2003, 192 (43), pp.4837-4873. ⟨10.1016/j.cma.2003.08.001⟩. ⟨hal-00705123⟩
172 Consultations
0 Téléchargements
