JOINT TRACE/TV NORM MINIMIZATION: A NEW EFFICIENT APPROACH FOR SPECTRAL COMPRESSIVE IMAGING - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mohammad Golbabaee
  • Fonction : Auteur
  • PersonId : 858934
Pierre Vandergheynst
  • Fonction : Auteur
  • PersonId : 839985
In this paper we propose a novel and efficient model for compressed sensing of hyperspectral images. A large-size hyperspectral image can be subsampled by retaining only 3\% of its original size, yet robustly recovered using the new approach we present here. Our reconstruction approach is based on minimizing a convex functional which penalizes both the trace norm and the TV norm of the data matrix. Thus, the solution tends to have a simultaneous low-rank and piecewise smooth structure: the two important priors explaining the underlying correlation structure of such data. Through simulations we will show our approach significantly enhances the conventional compression rate-distortion tradeoffs. In particular, in the strong undersampling regimes our method outperforms the standard TV denoising image recovery scheme by more than 17dB in the reconstruction MSE.
Fichier non déposé
hal-00705752 , version 1 (08-06-2012)
  • HAL Id : hal-00705752 , version 1
Mohammad Golbabaee, Pierre Vandergheynst. JOINT TRACE/TV NORM MINIMIZATION: A NEW EFFICIENT APPROACH FOR SPECTRAL COMPRESSIVE IMAGING. IEEE International Conference on Image Processing (ICIP 2012), Sep 2012, Orlando, Florida, United States. ⟨hal-00705752⟩
95 Consultations
0 Téléchargements
