> ?(s 2 ), the traffic is routed via the tunnel (?(s 1 ), ? 2 (s 1 )), and we have two subproblems with two sources: OP T ? (?(s 1 ), ?(s 2 ); [?(s 2 ), ? 2 (s 1 )? 1]) and ) See Figure 8 for an illus- tration ,
Suppose we have two nodes i and j, with i < j, i carrying the traffic of one source and j the traffic of the other source Suppose also that the traffic is destined to nodes in [j, u]. Let (i, ?(i)) denotes the longest tunnel from i (with ?(i) ? u) If ?(i) > j, then there exists an optimal solution where the traffic of i destined for the nodes in [?(i), u] uses as first tunnel (i, ?(i)) ,
Nearly linear time approximation schemes for Euclidean TSP and other geometric problems, Proceedings 38th Annual Symposium on Foundations of Computer Science, pp.554-563, 1997. ,
DOI : 10.1109/SFCS.1997.646145
Designing Hypergraph Layouts to GMPLS Routing Strategies, Proc. of the 16th International Colloquium on Structural Information and Communication Complexity (SIROCCO), pp.57-71, 2009. ,
DOI : 10.1109/TCOMM.2008.050601
URL : https://hal.archives-ouvertes.fr/inria-00428685
GMPLS label space minimization through hypergraph layouts, Theoretical Computer Science, vol.444, 2009. ,
DOI : 10.1016/j.tcs.2012.01.033
URL : https://hal.archives-ouvertes.fr/inria-00426681
Directed virtual path layouts in ATM networks, Theoretical Computer Science, vol.291, issue.1, pp.3-28, 2003. ,
DOI : 10.1016/S0304-3975(01)00394-2
URL : https://hal.archives-ouvertes.fr/inria-00073007
The Steiner problem with edge lengths 1 and 2, Information Processing Letters, vol.32, issue.4, pp.171-176, 1989. ,
DOI : 10.1016/0020-0190(89)90039-2
Creating multipoint-to-point LSPs for traffic engineering, IEEE Communications Magazine, vol.43, issue.1, pp.95-100, 2005. ,
DOI : 10.1109/MCOM.2005.1381881
Approximation Algorithms for Directed Steiner Problems, Proc. of the 9th Annual ACM-SIAM Symposium on Discrete Algorithms (SODA), pp.192-200, 1998. ,
DOI : 10.1006/jagm.1999.1042
A threshold of ln n for approximating set cover, Journal of the ACM, vol.45, issue.4, pp.634-652, 1998. ,
DOI : 10.1145/285055.285059
Optimal layouts on a chain ATM network, Discrete Applied Mathematics, vol.83, issue.1-3, pp.157-178, 1998. ,
DOI : 10.1016/S0166-218X(98)80002-4
Improved approximation algorithms for network design problems, Proc. of the 5th annual ACM- SIAM symposium on Discrete algorithms (SODA), pp.223-232, 1994. ,
Exploring the trade-off between label size and stack depth in MPLS routing, Proc. of IEEE INFOCOM, pp.544-554, 2003. ,
Traveling with a Pez Dispenser (or, Routing Issues in MPLS), SIAM Journal on Computing, vol.34, issue.2, pp.453-474, 2005. ,
DOI : 10.1137/S0097539702409927
Tree based MPLS routing, Proceedings of the fifteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '03, pp.193-199, 2003. ,
DOI : 10.1145/777412.777443
Biconnectivity approximations and graph carvings, Journal of the ACM, vol.41, issue.2, pp.214-235, 1994. ,
DOI : 10.1145/174652.174654
IST-LASAGNE: towards all-optical label swapping employing optical logic gates and optical flip-flops, Journal of Lightwave Technology, vol.23, issue.10, pp.2993-3011, 2005. ,
DOI : 10.1109/JLT.2005.855714
A sub-constant error-probability low-degree test, and a sub-constant errorprobability PCP characterization of NP, Proc. of the 29th annual ACM Symposium on Theory of Computing (STOC), pp.475-484, 1997. ,
Traffic engineering using multiple multipoint-to-point LSPs, Proceedings IEEE INFOCOM 2000. Conference on Computer Communications. Nineteenth Annual Joint Conference of the IEEE Computer and Communications Societies (Cat. No.00CH37064), pp.894-901, 2000. ,
DOI : 10.1109/INFCOM.2000.832264
All-Optical Label Stacking: Easing the Trade-offs Between Routing and Architecture Cost in All-Optical Packet Switching, IEEE INFOCOM 2008, The 27th Conference on Computer Communications, pp.655-663, 2008. ,
DOI : 10.1109/INFOCOM.2008.115
On optimal computation of MPLS label binding for multipoint-to-point connections, IEEE Transactions on Communications, vol.56, issue.7, pp.1056-1059, 2007. ,
Routing in all-optical label switched-based networks with small label spaces, 13th Conference on Optical Network Design and Modeling (ONDM), p.6, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00425298
Label Space Reduction in MPLS Networks: How Much Can A Single Stacked Label Do?, IEEE/ACM Transactions on Networking, vol.16, issue.6, pp.1308-1320, 2008. ,
DOI : 10.1109/TNET.2007.912382
Depth-First Search and Linear Graph Algorithms, SIAM Journal on Computing, vol.1, issue.2, pp.146-160, 1972. ,
DOI : 10.1137/0201010
Approximation Algorithms, 2003. ,
DOI : 10.1007/978-3-662-04565-7
