Evaluation codes from smooth quadric surfaces and twisted Segre varieties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Designs, Codes and Cryptography Année : 2013
We give the parameters of any evaluation code on a smooth quadric surface. For hyperbolic quadrics the approach uses elementary results on product codes and the parameters of codes on elliptic quadrics are obtained by detecting a BCH structure on these codes and using the BCH bound. The elliptic quadric is a twist of the surface P1 × P1 and we detect a similar BCH structure on twists of the Segre embedding of a product of any d copies of the projective line.
DCC_Couvreur_Duursma_final.pdf (181.54 Ko) Télécharger le fichier
hal-00707540 , version 1 (12-06-2012)
Alain Couvreur, Iwan Duursma. Evaluation codes from smooth quadric surfaces and twisted Segre varieties. Designs, Codes and Cryptography, 2013, 66 (1-3), pp.291-303. ⟨10.1007/s10623-012-9692-4⟩. ⟨hal-00707540⟩
Collections
CNRS IMB
94 Consultations
202 Téléchargements
