Abstract : In this work, we propose a novel approach for signal prediction based on the use of sparse signal representations and Matching Pursuit (MP) techniques. The paper first focuses on spatial texture prediction in a conventional block-based hybrid coding scheme and secondly addresses inter-layer prediction in a scalable video coding (SVC) framework. For spatial prediction the signal reconstruction of the block to predict is based on basis functions selected with the MP iterative algorithm, to best match a causal neighborhood. Inter-layer MP based prediction employs base layer upsampled components additionally to the causal neighborhood in order to improve the representation of high frequencies. New solutions are proposed for efficiently deriving and exploiting the atoms dictionary through phase refinement and mono-dimensional basis functions. Experimental results indicate noticeable improvement of rate/distortion performance compared to the standard prediction methods as specified in H.264/AVC and its extension SVC.
Type de document :
Article dans une revue
international journal on Visual Communication and Image representation (JVCI), Elsevier, 2011, 22 (8), pp.712-720
https://hal.inria.fr/hal-00709163
Contributeur : Christine Guillemot
Soumis le : lundi 18 juin 2012 - 09:29:11
Dernière modification le : lundi 18 juin 2012 - 09:29:11
HAL Id : hal-00709163, version 1
Citation
A. Martin J. J. Fuchs C. Guillemot D. Thoreau. Sparse representations for spatial prediction and texture refinement. international journal on Visual Communication and Image representation (JVCI), Elsevier, 2011, 22 (8), pp.712-720. 〈hal-00709163〉
