. [. Philips, Multi- Scale Surface Descriptors, IEEE Trans. Visualization and Comput. Graph, vol.15, issue.6 2, pp.1201-1208, 2009.
. [. Scopigno-r, A simple normal enhancement technique for interactive non-photorealistic renderings, Computers & Graphics, vol.29, issue.2 6, pp.125-133, 2005.
C. M. Do, Differential Geometry of Curves and Surfaces, 1976.
. [. Germann-m and . Gross-m, Dynamic sampling and rendering of algebraic point set surfaces, Computer Graphics Forum, vol.27, issue.2, p.5, 2008.
. [. Shimshoni-i and . Tal-a, Demarcating Curves for Shape Illustration, Proc. SIGGRAPH Asia), 2008.
]. Kst09a, . M. Kolomenkin, . Shimshoni-i, and . Tal-a, On edge detection on surfaces, IEEE conf. Comput. Vision and Pattern Recognition (CVPR) Ieee, pp.2767-2774, 2009.
]. Kst09b, . M. Kolomenkin, . Shimshoni-i, and . Tal-a, Prominent field for shape processing of archaeological artifacts, IEEE Int. Conf. Comput. Vision Workshop (ICCVW) Ieee, pp.915-922, 2009.
]. Mil94 and . G. Miller, Efficient algorithms for local and global accessibility shading, Proceedings of the 21st annual conference on Computer graphics and interactive techniques SIGGRAPH '94, pp.319-326, 1994.
K. T. Mkc-*-06-]-mertens, C. J. Bekaert-p, and D. F. , Texture transfer using geometry correlation, Rendering Techniques, pp.273-284, 2006.
W. [. and G. D. Am-brisco, Surface Enhancement Using Real-time Photometric Stereo and Reflectance Transformation, Eurographics Symposium on Rendering Eurographics, 2006.
. [. Belyaev-a and . Seidel-h.-p, Ridge-valley lines on meshes via implicit surface fitting, ACM SIGGRAPH SIGGRAPH '04, pp.609-612, 2004.
P. M. Kobbelt-l and . Gross-m, Point-based multiscale surface representation, ACM Trans. Graph, vol.25, pp.177-193, 2006.
[. S. Burns-m and . Decarlo-d, Exaggerated shading for depicting shape and detail, Proc. SIGGRAPH), pp.1199-1204, 2006.
[. Grimm-c and . Wyvill-b, Interactive decal compositing with discrete exponential maps, ACM Trans. Graph, vol.25, pp.605-613, 2006.
[. J. , M. W. Gooch-a, and . Gooch-b, The lit sphere: a model for capturing npr shading from art, No description on Graphics interface 2001, pp.143-150, 2001.
. Vpb-*-10a-], . R. Vergne, . Pacanowski-r, . Barla-p, . Granier-x et al., Radiance Scaling for Versatile Surface Enhancement, Proc. symposium on Interactive 3D and games (I3D), 2010.
. Vpb-*-10b-], . R. Vergne, . Pacanowski-r, . Barla-p, . Granier-x et al., Improving Shape Depiction under Arbitrary Rendering, IEEE Trans. Visualization and Comput. Graph. PrePrint, issue.2, pp.99-100, 2010.
C. W. Zhang-x, F. J. , and W. R. Peng-q, Perceptually-motivated Shape Exaggeration. The Visual Comp, Proc. CGI), pp.6-8, 2010.
T. [. Shamir-a, Relief Analysis and Extraction, Proc. SIGGRAPH Asia), pp.1-10, 2009.
