Journal articles
Schnyder woods for higher genus triangulated surfaces, with applications to encoding
Abstract : Schnyder woods are a well-known combinatorial structure for plane triangulations, which yields a decomposition into 3 spanning trees. We extend here definitions and algorithms for Schnyder woods to closed orientable surfaces of arbitrary genus. In particular, we describe a method to traverse a triangulation of genus g and compute a so-called g-Schnyder wood on the way. As an application, we give a procedure to encode a triangulation of genus g and n vertices in 4n+O(g log(n)) bits. This matches the worst-case encoding rate of Edgebreaker in positive genus. All the algorithms presented here have execution time O((n + g)g), hence are linear when the genus is fixed.
Document type :
Journal articles
Complete list of metadata
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-00712046
Contributor : Luca Castelli Aleardi Connect in order to contact the contributor
Submitted on : Tuesday, June 26, 2012 - 11:57:12 AM
Last modification on : Thursday, March 5, 2020 - 6:20:45 PM
Long-term archiving on: : Thursday, September 27, 2012 - 2:40:08 AM
File
SchnyderWoods_DCG09_Hal.pdf
Identifiers
Collections
Citation
Luca Castelli Aleardi, Eric Fusy, Thomas Lewiner. Schnyder woods for higher genus triangulated surfaces, with applications to encoding. Discrete and Computational Geometry, Springer Verlag, 2009, 42 (3), pp.489-516. ⟨10.1007/s00454-009-9169-z⟩. ⟨hal-00712046⟩
Share
Metrics
Record views
163
Files downloads
133
