Conference papers
Succinct Representation of Labeled Graphs
Abstract : In many applications, the properties of an object being modeled are stored as labels on vertices or edges of a graph. In this paper, we consider succinct representation of labeled graphs. Our main results are the succinct representations of labeled and multi-labeled graphs (we consider vertex labeled planar triangulations, as well as edge labeled planar graphs and the more general $k$-page graphs) to support various label queries efficiently. The additional space cost to store the labels is essentially the information-theoretic minimum. As far as we know, our representations are the first succinct representations of labeled graphs. We also have two preliminary results to achieve the main results. First, we design a succinct representation of unlabeled planar triangulations to support the rank/select of edges in ccw (counter clockwise) order in addition to the other operations supported in previous work. Second, we design a succinct representation for a $k$-page graph when $k$ is large to support various navigational operations more efficiently. In particular, we can test the adjacency of two vertices in $O(\lg k\lg\lg k)$ time, while previous work uses $O(k)$ time.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00713051
Contributor : Luca Castelli Aleardi Connect in order to contact the contributor
Submitted on : Thursday, June 28, 2012 - 11:56:37 PM
Last modification on : Tuesday, October 19, 2021 - 12:55:33 PM
Links full text
Identifiers
Collections
Citation
Jérémy Barbay, Luca Castelli Aleardi, Meng He, Ian J. Munro. Succinct Representation of Labeled Graphs. 18th International Symposium on Algorithms and Computation (ISAAC 2007), Dec 2007, Sendai, Japan. pp.316-328, ⟨10.1007/978-3-540-77120-3_29⟩. ⟨hal-00713051⟩
Share
Metrics
Record views
94
