The laplacian pyramid as a compact image code, IEEE Transactions on Communications, issue.1, pp.31-532, 1983. ,
Saliency sequential surface organization for free-form object recognition, Comput. Vis. Image Underst, vol.88, issue.3 2, pp.152-188, 2002. ,
Scalar field analysis over point cloud data, Discrete & Computational Geometry, vol.46, issue.2, pp.743-775, 2011. ,
Multiscale surface descriptors, IEEE Transactions on Visualization and Computer Graphics, vol.15, issue.6, pp.1201-1209, 2009. ,
Object detection with feature stability over scale space, Journal of Visual Communication and Image Representation, vol.22, issue.4, pp.345-352, 2011. ,
DOI : 10.1016/j.jvcir.2011.02.004
Topological persistence and simplification, Discrete & Computational Geometry, vol.28, pp.511-533, 2002. ,
Adaptive Discrete Laplace Operator, Advances in Visual Computing, pp.377-386, 2011. ,
Algebraic point set surfaces, ACM Trans. Graph, vol.26, issue.3 3, 2007. ,
Dynamic sampling and rendering of algebraic point set surfaces, Computer Graphics Forum, vol.27, issue.3, p.10, 2008. ,
Reassembling Fractured Objects by Geometric Matching, ACM Trans. Graph, vol.25, issue.3 2, pp.569-578, 2006. ,
Surface partial matching and application to archaeology, Computers & Graphics, vol.35, issue.2, pp.334-341, 2011. ,
The approximation power of moving leastsquares, Math. Comput, vol.67, issue.224, pp.1517-1531, 1998. ,
The approximation power of moving leastsquares, Mathematics of Computation, vol.67, pp.1517-1531, 1998. ,
Multi-scale features for approximate alignment of point-based surfaces, Proc. of the Eurographics symposium on Geometry processing, 2005. ,
Scale-Space Theory in Computer Vision, 1994. ,
Spectral Mesh Processing, Computer Graphics Forum, vol.21, issue.3, pp.1-1747, 2009. ,
DOI : 10.1111/j.1467-8659.2010.01655.x
Computational vision: information processing in perception and visual behavior, 2000. ,
A Wavelet Tour of Signal Processing, Third Edition: The Sparse Way, 2008. ,
Theory of edge-detection, Proc. of the Royal Society of London, pp.187-217, 1980. ,
Curvature computation on free-form 3-d meshes at multiple scales, Comput. Vis. Image Underst, vol.83, issue.2, pp.118-139, 2001. ,
Multi-scale feature extraction on point-sampled surfaces Point-based multiscale surface representation, Computer Graphics Forum ACM Trans. Graph, vol.22, issue.2 8, pp.281-290, 2003. ,
Integral invariants for robust geometry processing, Comput. Aided Geom. Des, vol.26, issue.2, pp.37-60, 2009. ,
A concise and provably informative multi-scale signature based on heat diffusion, Proc. of the Symposium on Geometry Processing, pp.1383-1392, 2009. ,
Scale-space filtering, Proc. of the Eighth international joint conference on Artificial intelligence, pp.1019-1022, 1983. ,
Scale-space tree and its hierarchy, Pattern Recognition Proc., 10th International Conference on, pp.103-108, 1990. ,
Bandwidth selection and reconstruction quality in point-based surfaces, IEEE TVCG, vol.15, issue.4, pp.572-582, 2009. ,
Robust principal curvatures on multiple scales, Proc. of the Eurographics symposium on Geometry processing, pp.223-226, 2006. ,
Surface feature detection and description with applications to mesh matching, CVPR, 2009. ,
Multi-scale classification of 3D objects, CVPR, pp.864-869, 1997. ,
Harmonic maps and their applications in surface matching, CVPR, pp.2524-2530, 1999. ,
