Automated Generation of Geometric Models for a Bulbous Trawler Ship - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
The objective of this work is to develop an automated geometric modeler for trawler ships including a bow, for shape optimization purpose. Two approaches are tested to generate a spline-based representation of the hull. For the first one, a starting shape without bow is deformed to reach a target composed of points or lines, while preserving the shape regularity using a penalty functional. For the second approach, a starting hull including a baseline bow is deformed by handling meta-parameters, such as bow length, thickness or orientation. The different approaches are finally illustrated for a realistic application.
RR-8011.pdf (3.63 Mo) Télécharger le fichier
hal-00714791 , version 1 (05-07-2012)
  • HAL Id : hal-00714791 , version 1
Louis Blanchard, Régis Duvigneau, Bernard Mourrain. Automated Generation of Geometric Models for a Bulbous Trawler Ship. [Research Report] RR-8011, INRIA. 2012. ⟨hal-00714791⟩
170 Consultations
272 Téléchargements
